Beta5
Beta5
by klausesser » Sat Dec 07, 2013 11:58 pm
Beta5 on Win7 64:
it´s kind of depressing me -
i set "architectural view" as default setting: doesn´t work at all.
I set control bar: i see it - but it has no function.
Re: Beta5
by mediavets » Sun Dec 08, 2013 12:09 am
klausesser wrote:Beta5 on Win7 64:
Can you do that via the GUI?
What do you mean - can we see a screenshot or better the tour online?
Which control bar? Added via the GUI?
Are you viewing the tour locally or online?
If locally use the View last built tour... button in PTP 2.x.
Which browser are you using?
Re: Beta5
by klausesser » Sun Dec 08, 2013 12:36 am
i can only use the GUI - i didn´t license PTP2 . . so i have no access to the xml . . .
i used the first control-bar design on top from the menue.
set "architectural view" as projection also from the menue - i want to use ONLY the archtitectural view.
i used the IE on Win7 locally.
Re: Beta5
by mediavets » Sun Dec 08, 2013 12:50 am
klausesser wrote:i can only use the GUI - i didn´t license PTP2 . . so i have no access to the xml . . .
OK.
I think that's the D-pad control bar - is that correct?
You got me there ...where is the setting for specifying architectural view'?
Which version of IE?
IE 10 and earlier versions have some problems with some features of tours created with PTP 2.x.
IE11 is now available for Windows 7.
Firefox seems to be the most reliable browser for viewing tours created with PTP 2.x on all platforms.
Did you use the View last built tour.... button in PTP 2.x to view the tour locally?
Likes: 3 posts
Liked in: 225 posts
Re: Beta5
by Destiny » Sun Dec 08, 2013 12:53 am
I thought the default view was the architectural view..
Re: Beta5
by klausesser » Sun Dec 08, 2013 1:02 am
OK.
Sorry, Andrew - i´m on my MacBook right now and the PC is shut down.
I´ll check tomorrow.
Re: Beta5
by klausesser » Sun Dec 08, 2013 1:03 am
Destiny wrote:I thought the default view was the architectural view..
I don´t know what´s the default projection - but it´s not architectural view.
Likes: 3 posts
Liked in: 225 posts
Re: Beta5
by Destiny » Sun Dec 08, 2013 1:05 am
If you click on the Architectural View an the Normal View, which is the default view, they are the same...
http://www.destinyvirtualtours.com/PTPV ... AView.html
PS.. Maybe right.. the Normal view does not seem to work... Might be a bug...
Likes: 3 posts
Liked in: 225 posts
Re: Beta5
by Destiny » Sun Dec 08, 2013 1:15 am
Yes a bug, the views don'y seem to know what to do...
destiny
Likes: 60 posts
Liked in: 169 posts
Re: Beta5
by benji33 » Mon Dec 09, 2013 10:37 am
At this time "Normal" view is the default view.
Architectural view can't be set as default view, but can be added into projectionMenu or contextMenu and seems bugged (http://www.kolor.com/forum/viewtopic.php?f=92&t=20776)
Normal view can't be removed at this time.
3 options to change view : context menu / projection menu / action on a plugin or hotspot.
Normal view and architectural should be very similar on a default zoom level.
Re: Beta5
by klausesser » Mon Dec 09, 2013 12:25 pm
benji33 wrote:Normal view and architectural should be very similar on a default zoom level.
I changed almost all my panos/tours to architectural view being default.
It´s essential for me to use it.
