Cut of Panorama-menue with Safari
ArneAlbers
by ArneAlbers » Fri Dec 06, 2013 12:22 pm
Hey there i have a problem concerning Safari-Browser.
Version 6.0.5 (8536.30.1)
Also 5.1.7 (7534.57.2)
and maybe all others...
To make the panoramamanue flexible (%with same as the Floorplan and orientated direktly under it) I edited the panoramamenue via sript:
<style>
div.kolorAreaContent ul.kolorMenu {
list-style: none; }
</style>
<script>
function fixMenuPositionAndStyle() {
var $menu = $('#panoramaMenu');
var $floorPlanContent = $("#floorPlan .floorplanContent");
if(!$menu.size() > 0 || !$floorPlanContent.size() > 0) {
setTimeout(fixMenuPositionAndStyle, 100);
return;
$menu.css('position', '');
$menu.css('width', '30%');
$menu.css('top', '');
// $menu.appendTo($("#floorPlanArea .kolorAreaContent"));
$menu.appendTo($floorPlanContent);
// make sure we have the last word if the menu position has been overridden
setTimeout(fixMenuPositionAndStyle, 400);
var fixMenuRunningTimer = null;
function deplayedFixMenuPositionAndStyle() {
if(fixMenuRunningTimer) {
clearTimeout(fixMenuRunningTimer);
fixMenuRunningTimer = setTimeout(fixMenuPositionAndStyle, 300);
$(window).resize(function(event) {
$(document).ready(function() {
window.addEventListener('orientationchange', deplayedFixMenuPositionAndStyle);
</script>
Do you have any idea to make this work in Safari too?
Best Wishes
Arne
after Coding: problem in Safari
after Coding: no problem in Firefox
Before coding: The usual position and orientation
Likes: 84 posts
Liked in: 186 posts
Re: Cut of Panorama-menue with Safari
by benji33 » Mon Dec 09, 2013 10:25 am
It's difficult to offer you a solution because I can't see your code. An url can help to help you to find a solution.
So an other problem is the events and actions of panoramaMenu on window resize. Is it taken in account into your script ?
ArneAlbers
by ArneAlbers » Mon Dec 09, 2013 10:31 am
Oh, here is the link:
http://www.proundmotion.de/vt/graef/faz.html
The Problem is only in Safari.
I filled in the script after exporting the tour. The Script is in faz.html
Do you need any more information? Thank you a lot!
Likes: 84 posts
Liked in: 186 posts
by benji33 » Mon Dec 09, 2013 10:47 am
First quick check.
IE10 ok
Firefox ok
Chrome : doesn't work. PanoramaMenu is never displayed. A script try to refresh often.
ArneAlbers
by ArneAlbers » Mon Dec 09, 2013 1:03 pm
Do you have any suggestion to get the optical effect without my added scrypt?
Likes: 84 posts
Liked in: 186 posts
by benji33 » Tue Dec 10, 2013 9:12 am
Better way I think is to use the panorama menu over the floorplan plugin.
Then into the krpano code activate the panorama menu on floorplan events () rather than ontourstart event.
Your code
<events name="kolorMenuEvents-panoramaMenu" keep="true" onTourStart="showKolorMenu-panoramaMenu();" hidetourcontrols="hideKolorMenu-panoramaMenu();" showtourcontrols="showKolorMenu-panoramaMenu();"/>
New code (remove the onTourStart event and add css rule to fit a display size for all items)
<events name="kolorMenuEvents-panoramaMenu" keep="true" hidetourcontrols="hideKolorMenu-panoramaMenu();" showtourcontrols="showKolorMenu-panoramaMenu();"/>
