to build tour is impossible now with new update -- urgent
mfoleary
by mfoleary » Fri Dec 06, 2013 1:12 am
I re opened a tour that was being developed using an earlier version -- now in Beta 5.
Every time build is selected the tour crashes.
This is a ten pano tour with a dead line.
It is an insufferable problem now -- completely blocking me from proceeding.
I look to the developers and to fellow users -- you're my only hope...
Likes: 80 posts
Liked in: 182 posts
Re: to build tour is impossible now with new update -- urgen
by benji33 » Fri Dec 06, 2013 9:28 am
What is present into your project ?
plugins / presets / hotspots
You can send your project .kpt file here for test. thanks.
andrew306
by andrew306 » Fri Dec 06, 2013 5:14 pm
mfoleary wrote:I re opened a tour that was being developed using an earlier version -- now in Beta 5.
Not sure but maybe the same problem I'm having, or similar (viewtopic.php?f=92&t=20479).
Try changing custom colors back to default if you've changed any in the style menu.
Good luck.
by klausesser » Fri Dec 06, 2013 6:18 pm
My suggestion: never use Alphas/Betas for serious production work.
best and good luck, Klaus
