Floor Plan / Offline View not working on Google Chrome
Toni Fong
Likes: 4 posts
by Toni Fong » Thu Dec 05, 2013 5:53 pm
Just to report Floor Plan buttons not working when accessing virtual tour offline on Google Chrome.
Some of my clients asks for offline virtual tours.
Thank you
Re: Floor Plan / Offline View not working on Google Chrome
by mediavets » Thu Dec 05, 2013 6:35 pm
Toni Fong wrote:Hello,
Thank you
Many more fetaures in PTP 2.x are implemented in javascript.
To work correctly the (Flash version of a) tour must be delivered from a web server.
If you view the tour offline using the View last built tour button in PTP 2.x it is delivered via lightweight built-in web server.
Alternatively you can try viewing the HTML5 version of the tour.
Or use an offline web ssrver.
I believe Chrome may have additional 'security issues/restrictions' with running javascript offline.
What plaforms would your clients wish to display offiline tours on?
Why do they wish to have offline tours?
osamaaf
Liked in: 5 posts
by osamaaf » Tue Dec 10, 2013 11:10 pm
I m interested in having a fix for this. I have clients requiring the virtual tour to be delivered on a DVD but when I try to open the floor plan it does not. Please suggest some fix.
Likes: 3 posts
Liked in: 226 posts
by Destiny » Wed Dec 11, 2013 1:56 am
Try adding the suffix ?html5=always with your url...
osamaaf
Liked in: 5 posts
by osamaaf » Wed Dec 11, 2013 9:40 am
Destiny wrote:Try adding the suffix ?html5=always with your url...
Thanks but it works only in Mozilla Firefox. What shall we do for Google Chrome and Internet Explorer?
by mediavets » Wed Dec 11, 2013 9:54 am
You need IE10 or later to view all features of PTP 2.x tours correctly. That means Windows 7 or 8.
osamaaf
Liked in: 5 posts
by osamaaf » Wed Dec 11, 2013 8:01 pm
mediavets wrote:
Yes I m using Windows 8.1 with latest Internet Explorer. I hope anyone from developers would respond here.
by mediavets » Wed Dec 11, 2013 8:40 pm
Until they do - check out this offline Web server:
http://www.server2go-web.de/
Likes: 65 posts
Liked in: 169 posts
by benji33 » Thu Dec 12, 2013 1:07 pm
For chrome with ?html5=always look after this page http://www.chrome-allow-file-access-from-file.com/
osamaaf
Liked in: 5 posts
by osamaaf » Tue Dec 31, 2013 11:26 am
@Kolor and @Experts
Please suggest how we can publish the virtual tour on a DVD so that floor plans and everything work. HTML5 is a good option but should be compatible with all major browsers as it is going to run from a DVD on client's computer. Please advise.
Likes: 65 posts
Liked in: 169 posts
by benji33 » Thu Jan 02, 2014 10:00 am
Problem is not HTML5 but security of browser with the javascript interface. Newest browsers have better security rules which can break javascript/html5 scripts on offline mode.
At this time the workaround is to :
- change Flash security rules on the target computer which read the tour. See here.
- or use a browser with less security rules in html5 mode. So Firefox with ?html5=always string added on the end of url.
