Problem with floorplan plugin
Maciek
by Maciek » Wed Dec 04, 2013 3:16 pm
In beta 5 I have a problem with displaying menu label for multi-level floor plan ( if no title )
when display the floor plan title is unchecked.
It was working well in the previous beta version.
When can I find links for previous beta 4 and 3?
I also have problem with capital letters in multifloor plan title...
regards and sorry for my english :)
Maciek
Likes: 84 posts
Liked in: 188 posts
Re: Problem with floorplan plugin
by benji33 » Thu Dec 05, 2013 10:52 am
Yes it's a bug.
Next release will correct this problem.
Workaround : You can check the display Title option and go back to the selected text only on next release of the software.
Users browsing this forum: No registered users and 8 guests
