Win7 64x
vesnice8
Win7 64x
by vesnice8 » Tue Dec 03, 2013 8:19 pm
Got some really big problems to open PTP 2.0 B5. (Think started with beta 3 or 4)
I installed and deinstalled ptp for about 5 times, because could not open.
Now it opens, BUT it takes for sure 2-3 minutes and it shows, 'no answer' (keine Rückmeldung, german). After waiting, not touching anything :-) the prog. starts.
During the procedure of 'no answer' the PTP box (developped by etc etc.) is like freezed on my screen all over all programs.
Thanx for help
Re: Win7 64x
by mediavets » Tue Dec 03, 2013 8:36 pm
vesnice8 wrote:Got some really big problems to open PTP 2.0 B5. (Think started with beta 3 or 4)
Thanx for help
What is your hardware spec.?
CPU, RAM, GPU etc?
vesnice8
Re: Win7 64x
by vesnice8 » Tue Dec 03, 2013 9:42 pm
I'll let you know tomorrow. No access now :-)
Thanks in advance
Likes: 14 posts
Re: Win7 64x
by bdd » Wed Dec 04, 2013 9:43 am
How do you open PTP ?
Do you try to open it "empty", by clicking on the Panotour Pro icon in the desktop or in the explorer ?
Or do you try to open it on a project file, by double clicking on a project ?
If it is the second case, can you send us the project file ?
vesnice8
Re: Win7 64x
by vesnice8 » Wed Dec 04, 2013 11:42 am
Good mornig everybody
So, her some infos: Intel Core i7-3930K , 3.2 Ghz, RAM 64GB, NVIDIA GeForce GTX660
It is always the same problem. Doesen't matter opening by project, icon or explorer.
Sometimes with white screen, sometimes not...But as said, after approx. 1-2 minutes PTP is opening.
Thanx for help
