simple button changes destination
diax
by diax » Sun Dec 01, 2013 10:13 pm
First i would like to say that i am really impressed with PTP B5. There is so much possible.
Some bugs i noticed;
I use some simple buttons with a small picture to load a panorama. Sometimes they all point to the same panorama. After a save project ,exit PTP and start PTP and load project the same. All my 5 buttons point to the same panorama. Some buttons do another action after the load panorama and that remains intact.
Windows 7 /64 bits.
PTP B5
Re: simple button changes destination
by mediavets » Sun Dec 01, 2013 11:36 pm
diax wrote:Hello,
Windows 7 /64 bits.
PTP B5
Confirmed - PTP 2.0 beta 5 64-bit on Windows 8.1 Pro.
sarahbiebl
by sarahbiebl » Tue Jan 07, 2014 11:44 am
Same here! MAC OS X Version 10.8.5
Please fix it soon :(
Likes: 13 posts
Liked in: 112 posts
by bdd » Tue Jan 07, 2014 1:36 pm
sarahbiebl wrote:Same here! MAC OS X Version 10.8.5
Hello Sarah,
Which version of PTP2.0 are you using ?
Is is the last one, PTP2.0 RC1 ?
sarahbiebl
by sarahbiebl » Fri Jan 10, 2014 12:03 pm
Hello Sarah,
Hi Gérald.
It occures when I was using Beta 5 – couldn't try it out in RC1 because a new, bigger problem occures: A costumer wants to have another virtual tour with now over 300 panorama files. I could load all files in the tour and link them - but when I close the saved project and try to open again it crashes > can't open it anymore. Reinstalling Beta 5, when I have over, like, 200 file, the same prob occures, so this is a more serious problem then the one I mentioned here. I tried to compress the files, but at a point there is no compression possible without losing our standard of quality. You have some tipps?
Btw, I tried to open the saved project with that bigger mass of files in serveral ways, but no one did work.
(I know I have to open a new topic for this prob, I do instantly!)
THANKS!
