Bug on description panel (doesn't change/refresh)
photoericlopez
by photoericlopez » Fri Nov 29, 2013 5:22 pm
Hello
I need help for this bug. The description panel doesn't refresh: when I change to see another photo, the description stay the same even waiting a long time...
Only way to work : close project, open it again, modify one description and closing and opening again and again (be waiting 20 minutes)
thanks for help
Re: Bug on description panel (doesn't change/refresh)
by mediavets » Fri Nov 29, 2013 5:48 pm
photoericlopez wrote:Hello
thanks for help
Welcome to the forum...
I cannot reproduce this behaviour with PTP 2.0 beta 5 64-bit on Windows 8.1 pro.
What version are you using, and on which OS?
photoericlopez
by photoericlopez » Fri Nov 29, 2013 6:05 pm
I use Panotour pro 2.0 Beta 4 with windows 7 64bits
by mediavets » Fri Nov 29, 2013 6:23 pm
photoericlopez wrote:I use Panotour pro 2.0 Beta 4 with windows 7 64bits
Try upgrading to beta 5:
http://www.kolor.com/download-autopano- ... tware.html
photoericlopez
by photoericlopez » Sat Nov 30, 2013 12:07 am
ok I'm now with the Beta 5 but my project file can't be loaded (crash and close) whitout any click during the loading... =|
HarryA360
by HarryA360 » Sat Nov 30, 2013 10:36 am
Same sort of problem over here.
When you placed HTML based information in the panorama-description, randomly the text show up or not.
Note:
it seems like this only happens when you paste HTML-based text in the descriptionbox. For example, a lorem ipsum generated text with tags in it (http://loripsum.net/).
photoericlopez
by photoericlopez » Sat Nov 30, 2013 10:43 am
In my case I've only put a fiew words in description, no html link...
It's when i change the selected photo, the program seems buzy and description stay like the one of the previous photo...
And Beta 5 doesn't work with this projet !!!!! but the program works opening a new project or opening a 1.8 version project !!!
HarryA360
by HarryA360 » Sat Nov 30, 2013 10:51 am
Seem like there are more problems with the description-plugin.
Hope Kolor dive in to this to solve the problems.
HA
by mediavets » Sat Nov 30, 2013 11:09 am
photoericlopez wrote:In my case I've only put a fiew words in description, no html link...
Perhaps your beta 4 project has become corrupted?
by mediavets » Sat Nov 30, 2013 11:10 am
HarryA360 wrote:Same sort of problem over here.
Note:
What do you mean by 'HTML-based text'?
HarryA360
by HarryA360 » Sat Nov 30, 2013 12:14 pm
The easiest way to make myself clear:
Go to http://loripsum.net/, select some tag’s (screen left site) and generate.
Copy generated text an paste it in to a panoramic description.
Save, close and reopen project.
Now build an view the tour.
The panorama description text randomly shows up or not.
Second strange behavior :
The description box remains empty, but the text is displayed in the browser.
Ummmm have to look further to bypass this error.
HA
by mediavets » Sat Nov 30, 2013 12:31 pm
HarryA360 wrote:Hmmmm have to look further to bypass this error.
HA
Did you expect the Description field to accept and display correctly this sort of copy-n-pasted 'HTML-based text ' content?
HarryA360
by HarryA360 » Sat Nov 30, 2013 12:40 pm
Yes.... and it does, unfortunately not all the time. :cool:
For now only one solution, go back to plain text ;)
I've deleted al text in the description boxes, and now build up the descriptions again.
Likes: 3 posts
Liked in: 215 posts
by Destiny » Sat Nov 30, 2013 2:38 pm
The Description box does not support html edited formatting.. Its only a limited plain text option...
It will support an email or web url.. Thats about it...
photoericlopez
by photoericlopez » Sat Nov 30, 2013 8:51 pm
Nooo!! i'm afraid you're all right... because my file doesn't open with the beta 4 version anymore !
Any idea to repair a project file because my backup file is too old !
Likes: 60 posts
Liked in: 169 posts
by benji33 » Mon Dec 02, 2013 9:11 am
Try to find text into the .kpt and remove it (blank text) to try again.
Look after description="YOUR_TEXT" into <pano ...> HERE </pano> tags.
Do you use ' (simple quote) into the text ?
photoericlopez
by photoericlopez » Wed Dec 04, 2013 9:46 pm
benji33 wrote:Do you use ' (simple quote) into the text ?
Yes. Can I ?
by mediavets » Wed Dec 04, 2013 10:01 pm
Yes. Can I ?
I believe it causes problems in Beta 5.
Likes: 60 posts
Liked in: 169 posts
by benji33 » Thu Dec 05, 2013 10:13 am
Yes it seems that simple quote broke description, you can try to make texts without quote and update desc when next release will be done.
photoericlopez
by photoericlopez » Sat Dec 07, 2013 9:19 pm
Ok thanks for help.
