3rd Party JS or JQuery Media White Flash
Liked in: 226 posts
by Destiny » Fri Nov 29, 2013 2:56 am
@ Benjamin..
I was expecting that the white flash bug I reported a while back was resolved in this B5 version but its not to be..
This is the link WITH the white flash, on first load...
http://www.destinyvirtualtours.com/PTPV ... eText.html
This is the same files where I replaced the KolorBox.min.js with your bug fix file... Its works... No white flash on first load..
I hope your bug fix will be in the next B6....
Likes: 82 posts
Liked in: 184 posts
Re: 3rd Party JS or JQuery Media White Flash
by benji33 » Fri Nov 29, 2013 4:39 pm
Seems odd because patch is into, but others modifications can impact probably.
Can you try this file. Thanks
KolorBox.min.js
(30.51 KiB) Downloaded 22 times
Liked in: 226 posts
by Destiny » Fri Nov 29, 2013 11:03 pm
That file does not work Ben, it creates the white flash.. If I swap it back for your first files you sent me, it works well....
