Panorama Menu has inconsistent tranparency
jschrader
Liked in: 3 posts
by jschrader » Sat Nov 23, 2013 7:44 pm
I'm using a panorama menu at the top of my tour and the background color has a transparency setting.
I also use the option "Extend menu to the tour size".
On my screen the menu items cover about half the length of the bar.
That part of the bar that doesn't contain the menu items (= the extended part) has a significantly lighter transparency than the rest of the bar, which is odd, looks ugly and should not be the case.
Please fix it or give me a good reason why that is considered a desired feature.
Re: Panorama Menu has inconsistent tranparency
by mediavets » Sat Nov 23, 2013 9:18 pm
jschrader wrote:I'm using a panorama menu at the top of my tour and the background color has a transparency setting.
I cannot see what you are talking about:
jschrader
Liked in: 3 posts
by jschrader » Sun Nov 24, 2013 5:57 am
You mean you don't see that there's a difference between the part of the bar where the text is and the rest of the bar?
by mediavets » Sun Nov 24, 2013 9:00 am
jschrader wrote:You mean you don't see that there's a difference between the part of the bar where the text is and the rest of the bar?
Yes, I see that.
It's intententional, to display a Button effect for menu items.
Perhaps Kolor could/should add a Button colour parameter in the plugin so you could set the Button colour to match the Background colour to do away with the Button effect? Or make it more emphatic by choosing a contrasting colour, as is offered for selected buttons.
jschrader
Liked in: 3 posts
by jschrader » Sun Nov 24, 2013 4:27 pm
Doesn't make sense to me because as soon as there is more than one menu item there is no button effect. The button effect is created by choosing a "darker" or "lighter" color on over.
Also, if one wants to extend the bar across the entire size of the frame there is a reason. And the reason is design. With two different colors it's just useless.
by mediavets » Sun Nov 24, 2013 6:40 pm
jschrader wrote:Doesn't make sense to me because as soon as there is more than one menu item there is no button effect. The button effect is created by choosing a "darker" or "lighter" color on over.
I see the button effect with more than one menu item - what's more you can choose the spacing between buttons in the plugin parameters.
jschrader
Liked in: 3 posts
by jschrader » Sun Nov 24, 2013 6:54 pm
I am aware of the spacing but that makes it ugly ^3 :p
To solve the issue and satisfy both camps there should be an option to treat bg and main menu independently with individual values. THAT would make it intentional ;-)
by mediavets » Sun Nov 24, 2013 7:12 pm
jschrader wrote:I am aware of the spacing but that makes it ugly ^3 :p
Or one might say that makes the button effect.
Which is what I suggested/proposed here I think?
viewtopic.php?f=92&t=20627&p=131875#p131832
by mediavets » Mon Nov 25, 2013 8:03 pm
I have a possible workaround for you.
Make the background for the Panorama menu plugin completely transparent and place it on top of a Coloured area plugin.
jschrader
Liked in: 3 posts
by jschrader » Tue Nov 26, 2013 5:04 am
Looks promising, thank you very much for taking your time.
Likes: 84 posts
Liked in: 188 posts
by benji33 » Thu Nov 28, 2013 10:22 am
Button effect (on/off) has been added into features list. Thanks for report
Users browsing this forum: No registered users and 8 guests
