Floor Plan Moves on iPad Orientation
RS360VTS
Liked in: 3 posts
by RS360VTS » Wed Nov 20, 2013 5:01 pm
I have just created a tour where the 40% wide/60% High floor plan area is set 100px up from the bottom center.
Works great on the PC, but when I view on my iPad, initially it is as expected when viewed landscape but if you then rotate the iPad by 90degrees to portrait, the floor plan completely moved to 100px up from dead centre instead of centre bottom. Then when I turn the ipad back to landscape it is now 0pixels up from centre bottom...
Help, as I need to get jobs out and want to be able to use PTP2
rs360vts
As initially opened.
On Turning to Portrait
On returning to Landscape
RS360VTS
Liked in: 3 posts
Re: Floor Plan Moves on iPad Orientation
by RS360VTS » Wed Nov 20, 2013 5:09 pm
If you want to have a look at the tour, on an iPad or other device, here is the url...
http://www.360virtual-tours.net/Tours/C ... nTour.html
rs360vts
by benji33 » Thu Nov 21, 2013 9:45 am
Added into bug report for a check on orientation change.
