Gallery Plugin does not recognise Numbers
RS360VTS
Liked in: 3 posts
by RS360VTS » Tue Nov 19, 2013 4:24 pm
It would appear as though the Gallery Plugin does not recognise numbers.
I wanted to add 3 images in the gallery. I called them:
2Floor.png when I ran the gallery it showed GFloor, 2Floor, 2Floor
When I looked in the folder "Gallery" it had converted the 1Floor and 2Floor to read _floor for both images.
The only way aroud it was to rename the images FirstFloor and SecondFloor, then it worked as it should.
A minor inconvenience, but a bug none the less...
RS360VTS
Re: Gallery Plugin does not recognise Numbers
by benji33 » Wed Nov 20, 2013 3:09 pm
Yes I open a bug report. Thanks
