Hwo many galleries are possible?
zebragruen
by zebragruen » Tue Nov 19, 2013 9:25 am
ptp2.4 win7
How many different galleries can be attatched into a tour?
I tested 5 gallieries, but can link only two different ones.
regards
Alex
Re: Hwo many galleries are possible?
by benji33 » Tue Nov 19, 2013 9:31 am
Should be as many as you want.
zebragruen
by zebragruen » Tue Nov 19, 2013 9:55 am
OK, then I don't understand how it works.
First a collect my pics in the "gallery" and give it a new name.
In result I have several galleries with different names on the left side of "styles".
How do I link them? I chose the polygon to link them, but this brought me just to the point, that I could link only two galleries.
by mediavets » Tue Nov 19, 2013 10:02 am
zebragruen wrote:OK, then I don't understand how it works.
You will need to create a separate Polygon hotspot style to open each of the galleries.
Then choose the appropriate style instance when you draw your Polygon hotspot.
zebragruen
by zebragruen » Tue Nov 19, 2013 10:45 am
I did it. In result I created 4 galleries. But the number 4 overwrites number 3.
In result I still have 3 galleries to refer to.
Is it correct, that a gallerie is created automatically, when I collect my photos in the mask and give the thing a new name? I appers automatically on the left side.
by mediavets » Tue Nov 19, 2013 10:56 am
zebragruen wrote:I did it. In result I created 4 galleries. But the number 4 overwrites number 3.
I don't understand what you mean.
I have no problem creating multiple instances of the Gallery plugin, just keep clicking on the Gallery plugin in the Plugins Library on the right and each time you'll see another instance appear in your Workspace on the left
zebragruen
by zebragruen » Tue Nov 19, 2013 11:11 am
I found my mistake. Thanks!
I always have to use the stuff on the right side again, to fill a new one on the left side.
Good guy!!
