New Update: Export tour is blank black screen
rage_zi
by rage_zi » Mon Nov 18, 2013 1:46 pm
Just updated Panotour Pro and exported the project I've been working on. the tour is now a blank black screen, even though all the files still accounted for. In comparison, an older version that I backed up before I updated still works fine. Any thoughts?
R
Re: New Update: Export tour is blank black screen
by mediavets » Mon Nov 18, 2013 2:03 pm
rage_zi wrote:Just updated Panotour Pro and exported the project I've been working on. the tour is now a blank black screen, even though all the files still accounted for. In comparison, an older version that I backed up before I updated still works fine. Any thoughts?
R
Welcome to the forum...
Which version of PTP did you upgrade from and to?
Is then when viewing locally?
If so, are you using the View last built tour.. button in PTP 2.x to view?
What browser and OS are you using to view the tour?
by benji33 » Mon Nov 18, 2013 4:22 pm
Is it the same that this bug ?
See : http://www.kolor.com/forum/viewtopic.php?f=92&t=20486 and try with url options.
rage_zi
by rage_zi » Mon Nov 18, 2013 7:06 pm
Hey,
Thanks for the quick replies guys, sorry for being so vague.
mediavets:
- I upgraded to Panotour Pro 2.0 Beta 4 from what I can only assume was Beta 3
- This is while viewing locally but also when I run Apache with XAMPP Control, so online as well.
- Browser is Chrome running on Mac 10.9 OSX
benji33:
I tried the steps outlined on that post, unfortunately to no effect. So it would seem something else is the problem here.
by mediavets » Mon Nov 18, 2013 7:21 pm
rage_zi wrote:- I upgraded to Panotour Pro 2.0 Beta 4 from what I can only assume was Beta 3
Did you try Firefox?
by benji33 » Tue Nov 19, 2013 9:24 am
Seems odd because on MacOS sometime webgl is not activated, but css3d or flash should work.
Do you have a sample online with black blank screen on your browser please ?
What are the difference, plugins used, colorization of icons, ... between you're working projects and this one ?
rage_zi
by rage_zi » Wed Nov 20, 2013 5:33 am
Hey,
Here are two links
working older pano tour: http://goo.gl/OE6OCJ
upgraded and then exported blank tour: http://goo.gl/JT7k4H
The only thing I changed was removing three images that were in one of the 360's. Aside from that, nothing has been added or taken away.
by benji33 » Wed Nov 20, 2013 2:53 pm
Is it possible to update this file ?
http://www.rajanzaveri.com/rajanzaveri/ ... e_text.png
Because for me it's corrupted.
You can try to upload again the whole tour to see if it's an upload problem.
rage_zi
by rage_zi » Thu Nov 21, 2013 3:44 am
Hahah Nice one Benji33!!
You hit the nail on the head, after replacing the corrupted file the tour is all smooth sailing.
cheers for that mate!
R
