Crash after build again pano
herflik89
by herflik89 » Sat Nov 16, 2013 11:04 am
Hi, I'm new here, I have a problem with Panotour.
I've created tour with 28 panos, after first build everything seems to be ok. But when I edited some spots, and build it again the program crashed.
I'm using OS X Mavericks (same problem appears on OS X Lion) and Panotour v2.0 beta 4.
Re: Crash after build again pano
by mediavets » Sat Nov 16, 2013 11:52 am
herflik89 wrote:Hi, I'm new here, I have a problem with Panotour.
Welcome to the forum...
Did you create the tour originally with beta 4 or with an earlier beta version?
herflik89
by herflik89 » Sat Nov 16, 2013 12:29 pm
I've made it in earlier version but i had the same problem, and than I updated panotour to newest version and problem didn't disapear.
by mediavets » Sat Nov 16, 2013 12:37 pm
herflik89 wrote:I've made it in earlier version but i had the same problem, and than I updated panotour to newest version and problem didn't disapear.
OK - try removing and then replacing all plugins in your Workspace in the Style section.
herflik89
by herflik89 » Sat Nov 16, 2013 1:41 pm
I don't have any plugins on workspace. I've tried to add one but it still doesn't work.
by mediavets » Sat Nov 16, 2013 1:45 pm
herflik89 wrote:I don't have any plugins on workspace. I've tried to add one but it still doesn't work.
So you have no Control bar, no menu of any sort?
How do you allow the user to control the tour? Just via hotspots?
herflik89
by herflik89 » Sat Nov 16, 2013 1:47 pm
Yes, but this tour was first built and I want to check if it work. I wanted to add menu in next steps.
by mediavets » Sat Nov 16, 2013 2:00 pm
herflik89 wrote:Yes, but this tour was first built and I want to check if it work. I wanted to add menu in next steps.
OK.. so with which version did you first build the tour?
Did it work then?
herflik89
by herflik89 » Sat Nov 16, 2013 2:07 pm
First I've created it in Beta 2 but it was the same problem, and I decide to update.
by mediavets » Sat Nov 16, 2013 2:23 pm
herflik89 wrote:First I've created it in Beta 2 but it was the same problem, and I decide to update.
Have you ever managed to complete a Build of this tour?
herflik89
by herflik89 » Sat Nov 16, 2013 2:27 pm
Yes, first time on Beta 2. I've saved the project on this version and in Beta 4 i can't build it.
by mediavets » Sat Nov 16, 2013 2:45 pm
herflik89 wrote:Yes, first time on Beta 2. I've saved the project on this version and in Beta 4 i can't build it.
Do you have any unusual, special or accented characters in the folder/directory an file names anywhere in the tour?
I wonder whther this thread may also be relevant?:
viewtopic.php?f=2&t=20521&p=131143#p131130
herflik89
by herflik89 » Sat Nov 16, 2013 2:51 pm
If this characters are "_" - yes. In every file I have this character.
by mediavets » Sat Nov 16, 2013 3:08 pm
herflik89 wrote:If this characters are "_" - yes. In every file I have this character.
No, that should not cause a problem.
Did you look at this thread:
Perhaps at this point it would be best to start again and create the tour afresh in Beta 4?
herflik89
by herflik89 » Sat Nov 16, 2013 5:21 pm
Thanks for your help. I've solved the problem. It was really simple, previously I've created my different hotspot style and I've changed color of them. This was the problem - changed color of hotspot :)
Once again, thanks for help:)
Cya :)
by mediavets » Sat Nov 16, 2013 5:47 pm
herflik89 wrote:Thanks for your help. I've solved the problem. It was really simple, previously I've created my different hotspot style and I've changed color of them. This was the problem - changed color of hotspot :)
Cya :)
So changing the colour of a hotspot style causes a crash on Build?
herflik89
by herflik89 » Sat Nov 16, 2013 5:49 pm
Exactly:)
by mediavets » Sat Nov 16, 2013 5:50 pm
herflik89 wrote:Exactly:)
Are you going to make a bug report about that?
herflik89
by herflik89 » Sat Nov 16, 2013 5:51 pm
I don't know how :)
by mediavets » Sat Nov 16, 2013 5:54 pm
herflik89 wrote:I don't know how :)
Simple...
Start a new topic about the problem.
Describe the setup you are using - versions of software and OS.
Describe how to reproduce the fault.
by mediavets » Sat Nov 16, 2013 6:06 pm
What sort of hotspot wrer you changing the colour of?
It doesn't cause a crash - on Build - for me when changing the icon and/or colour in a Point hotspot style.
PTP beta 3 on Windows 7.1 64-bit.
by benji33 » Mon Nov 18, 2013 1:02 pm
It's probably due to TEMP directory of OSX Maverick. TEMP directory in Mavericks change.
So try to define it again with Edit > Preferences > Performances => Temporary folders.
This folder is used by icon colorization algorithm.
Thanks for your return.
