ERROR: remove - unknown array item - eventKrpanoLoadedEvts
swisspano
by swisspano » Fri Nov 15, 2013 7:14 pm
Since Update to PTP 2.0 Beta 3 and Beta 4 I get always the following message:
This message does only appear if I open my tour online on my windows desktop browsers (Firefox, Safari, IE). The message does not appear if I watch the tour on my mobile devices or offline on my desktop.
http://www.appenzellerlinks.ch/Appenzellerland/Panoramatour/Kugelpanorama-Tour-Alpstein.htm
Any ideas?
Likes: 80 posts
Liked in: 182 posts
Re: ERROR: remove - unknown array item - eventKrpanoLoadedEv
by benji33 » Mon Nov 18, 2013 1:53 pm
Is it possible to make a test ?
Into the Alpsteintour.xml file, change the 2 last lines :
<events name="eventKrpanoLoadedEvts" onxmlcomplete="events.removearrayitem(eventKrpanoLoadedEvts);eventKrpanoLoadedAction();" keep="true"/>
<action name="eventKrpanoLoadedAction">js(eventKrpanoLoaded());</action>
By these ones :
<events name="eventKrpanoLoadedEvts" onxmlcomplete="eventKrpanoLoadedAction();" keep="true"/>
<action name="eventKrpanoLoadedAction">events.removearrayitem(eventKrpanoLoadedEvts);js(eventKrpanoLoaded());</action>
Thanks.
swisspano
by swisspano » Mon Nov 18, 2013 7:36 pm
Hi Benjamin
Thank you for your reply.
I changed the last 2 lines as suggested by you. But it didn't help.
Any other ideas?
Likes: 80 posts
Liked in: 182 posts
by benji33 » Tue Nov 19, 2013 9:19 am
Can you try and report me the result of this code to replace into the main XML ?
  <events name="eventKrpanoLoadedEvts" onxmlcomplete="eventKrpanoLoadedAction();" keep="true" />
  <action name="eventKrpanoLoadedAction"{% if secure %} secure="true" {%endif%}>
    <!-- events.removearrayitem(eventKrpanoLoadedEvts); -->
    set(events[eventKrpanoLoadedEvts].name, null);
  </action>
swisspano
by swisspano » Tue Nov 19, 2013 7:29 pm
With the new code I get the following error message:
FATAL: Alpsteintourdata/Alpsteintour.xml - XML parser error: element is malformed (#1090)
Likes: 80 posts
Liked in: 182 posts
by benji33 » Wed Nov 20, 2013 9:02 am
Sorry It's my fault cade is :
  </action>
swisspano
by swisspano » Wed Nov 20, 2013 6:59 pm
With the new code everything works correct.
Thanks a lot for your support Benjamin!
Likes: 80 posts
Liked in: 182 posts
by benji33 » Thu Nov 21, 2013 10:57 am
Good.
Is it possible to send me the .kpt file of your project for internal tests ?
Here or in private message. Thanks a lot.
