Description
reinhardkiss
Description
by reinhardkiss » Fri Nov 15, 2013 4:49 pm
since yesterday (beta 4) there is a problem with the description. The same description appears in each pano, no matter if I put it into the description box on the panorama-level, or in the box on the hotspot-level.
This behavior should be investigated by the team. Also the editor behaves a little strange.
Thank you
Alex
Re: Description
by benji33 » Mon Nov 18, 2013 3:56 pm
Seems odd into Panotour interface your descriptions texts are differents ?
Do you have a tour sample online for tests ?
