PTP 2.0 Beta 4 ... Save extended as... error
by mediavets » Fri Nov 15, 2013 12:52 pm
Scenario - PTP 2.0 beta 4 64-bit on Windows 8.1 Pro 64-bit...
Open project created with Beta 3 in bet 4.
Attempt Save extended as.. to a new folder with a new project filename.
I end up with the error message shown below.
Likes: 14 posts
Re: PTP 2.0 Beta 4 ... Save extended as... error
by bdd » Fri Nov 15, 2013 4:52 pm
Andrew,
Did you modify the default polygon spot style ?
If yes, what did you do exactly ?
Do you got same error with a new project created with this beta 4 ?
I do not reproduced this bug that's why I ask for more details.
