Gallery
Gallery
by Destiny » Fri Nov 15, 2013 9:48 am
Beta 4 - Mac
Hi...
It seems that the Gallery is now working in Beta 4... However, via the XML code I used to be able to add the Title and Description but its not possible anymore, at least not with Mac.... A strange graphic appears at the top left with no Gallery displaying...
I feel that I would like to see my Gallery nested in the pano at a set size or percentage of the pano... At the moment it take up the entire hight in the case of this test Gallery..
http://www.destinyvirtualtours.com/PTPV ... yTest.html
Re: Gallery
by Destiny » Fri Nov 15, 2013 11:32 pm
I have edited the xml to set the title to true and added title text..
Now there seems there is no option to add any titles or description.... It used to work really well... Not sure which version this issue began...
Destiny....
Re: Gallery
by benji33 » Mon Nov 18, 2013 4:19 pm
Ok seems strange. I'll have a look. Thanks Destiny.
