osmica wrote:OK, but how exactly. There are no instructions yet. Last time I tryed that spots wasn't visible. It seams I've made something wrong. I suppose I need to double click on the right side in the Library and than a new spot will be created on the left side where I can change its style.
After that I double clicked the spot to put it in the tour and than when I am adding a new spot, I need to select one of the spot styles I have there in the top right corner. Is that the right procedure?
osmica wrote:I have created a new tour with a few panos and spots are working there. But in the large tour I am working, spots and floor plans don't displays. Look this screenshot:
I marked strange files and folders. The folder for spots has not been created but an empty file "spots" instead. Also the 3 floor plans I used are located in the folder "floorplan" and named by PTP with extensions 54, 35, 42 but the groups folder "apartment_1_54" "apartment_2_35" "apartment_3_42" are all empty with no content. I think this are problems of PTP and not mine. I really don't understand why PTP don't build the tour as it needs like in my second tour. Is there anything that I can do, like reset something?? Otherwise I would need to recreate the whole tour from scratch.
osmica wrote:There is one strange thing about how Floor Plans are working...
For example, assign a floor plan to a group. Than click the floor plan properties inside a group and you will see the little floor plan (on the right in properties) but to view/edit the spots you need to click on the EDIT SPOTS. And here is the strange issue...You will get the floor plan with spots but on the right side will display the TOUR properties, instead the GROUP properties in which you are working. I understand it doesn't matter probably but it is confusing. Or maybe that is my problem why it doesn't work for me. I have installed the multifloor plugin. Can you tell me something about, please?
mediavets wrote:osmica wrote:I have created a new tour with a few panos and spots are working there. But in the large tour I am working, spots and floor plans don't displays. Look this screenshot:
Have you tried Building (not recreating) the tour again with new name into a new folder?
mediavets wrote:osmica wrote:There is one strange thing about how Floor Plans are working...
You can a Floorplan for the entire Project and/or fFoorplans for each Group.
So..
You add a Floorplan plugin from the Plugins Library to the Workspace and parameterise as you wish, in the Style section..
Then You use the project properties and Group properties to select the Floorplan(s) graphics you wish to use, in the Tour section.
To set hotspots on the Floorplan(s) you click on the icons in the group container border to display the Floorplan graphics in the hotspot editor.
You can control the display of the Floorplan(s) via an icon in a Control bar, or via a hotspot, or via a Simple button, or via a Toggle Button.
benji33 wrote:For screen 2 it's a bug. Beta 5 available today resolves it.
Is your spots directory always broken (under which beta version) ?
