MY FLOOR PLAN DISSAPPEAR
pitipon
by pitipon » Wed Nov 13, 2013 11:13 pm
PANOTOUR 2.0 beta2
Window32bit
When I open web via Panotour2.0, It is still ok.
(http://localhost:31415/virtualtour.html)
BUT, When I check in my folder and click directly.
Floor plan, it disappear!!
Re: MY FLOOR PLAN DISSAPPEAR
by mediavets » Wed Nov 13, 2013 11:23 pm
Many more features are implemented in javascript in PTP 2.x and must be delivered from a web server to operate correctly.
The View last built tour ... button delivers the tour via a lightweight built-in web server.
You can also access the tour via the localhost URL revealed when you use the View last built tour.... button.
Those features implemented in javascript will not work correctly when viewing locally when you link directly to the HTML file.
pitipon
by pitipon » Thu Nov 14, 2013 3:59 am
got it .. thanks
mediavets wrote:Many more features are implemented in javascript in PTP 2.x and must be delivered from a web server to operate correctly.
