Panotour 2 Crash IF Custom Colors Used (B2+B3+B4+B5)
andrew306
by andrew306 » Wed Nov 13, 2013 5:48 pm
Upon updating to Beta 2 Panotour crashes for me everytime when I press the Build button IF I have changed the default color of a Point in the style menu (also with Beta 3).
This is obviously pretty restricting and annoying. My trademark is quickly becoming "default purple".
Anyone else having this problem? Possible suggestions?
Re: Panotour 2 Crash IF Custom Colors Used (B2+B3)
by mediavets » Wed Nov 13, 2013 6:45 pm
andrew306 wrote:Upon updating to Beta 2 Panotour crashes for me everytime when I press the Build button IF I have changed the default color of a Point in the style menu (also with Beta 3).
I cannot replicate this problem with PTP 2.0 beta 3 on Windows 8.1 64-bit.
If you are working with a tour initially created using a version of PTP earlier than beta 1, then try removing then replacing all plugins.
andrew306
by andrew306 » Wed Nov 13, 2013 7:03 pm
I'm on vista 64-bit.
Tours created in any version do the same thing. Well I haven't tried rebuilding one in B3 yet. I'll give it a go and report back.
andrew306
by andrew306 » Wed Nov 13, 2013 7:59 pm
Ya. Tried rebuilding tour in B3. No extra plugins, changed default color of default point = crashy crash crash.
At least default purple is a nice purple. Any other suggestions out there?
by mediavets » Wed Nov 13, 2013 9:04 pm
andrew306 wrote:Ya. Tried rebuilding tour in B3. No extra plugins, changed default color of default point = crashy crash crash.
As you can see - below - I didn't have the problem.
What plugins are you using in your Workspace?
Do you see the Crash Reporter when the program crashes?
Does it crash immediatety you click on Build or later?
andrew306
by andrew306 » Wed Nov 13, 2013 10:34 pm
Sometimes the crash reporter comes up, sometimes not, I've filled it out and submitted it several times.
I can get my screen to look like that too. No problems until i press "build" then the white (empty) build bar appears at the bottom of the screen, but just when the bar usually starts filling up with green and status reports, then it just crashes, maybe 1 second into the build.
Likes: 84 posts
Liked in: 186 posts
by benji33 » Thu Nov 14, 2013 10:45 am
Is it possible to check the TEMP directory because colorization is done into a temp folder ?
If it's full or try to change it before a new build.
Into Panotour go to Edit > Preferences > Performances tab.
andrew306
by andrew306 » Wed Nov 27, 2013 8:44 pm
OK. Hi again.
Upgraded to beta 4 today.
Changed TEMP folder to a new one.
Still crashes IF default colors are changed, same as before.
- crash report uploaded-
Thanks for the help so far everyone. Anyone have any other suggestions?
(panotour 64-bit b4, windows vista)
by mediavets » Wed Nov 27, 2013 8:57 pm
andrew306 wrote:OK. Hi again.
Was this a new tour or a tour created with an earlier beta?
Do you uninstall earlier betas when you install the latest beta?
andrew306
Re: Panotour 2 Crash IF Custom Colors Used (B2+B3+B4)
by andrew306 » Wed Nov 27, 2013 10:14 pm
Initially I just updated b3 to b4 and tried to create a new tour = crash if default color changed.
So I just uninstalled, re-installed, built new tour. Still CRASHville.
grrr.
Likes: 84 posts
Liked in: 186 posts
by benji33 » Thu Nov 28, 2013 10:53 am
Ok I've added a bug report for verification. Thanks again for your tests.
andrew306
by andrew306 » Fri Nov 29, 2013 5:21 pm
benji33 wrote:Ok I've added a bug report for verification. Thanks again for your tests.
Groovy. Thanks.
andrew306
Re: Panotour 2 Crash IF Custom Colors Used (B2+B3+B4+B5)
by andrew306 » Tue Dec 03, 2013 8:49 pm
Update:
Uninstalled B4
Installed B5
Built tour with default colors - no problem
Saved
Closed
Re-opened Tour
Opened Style Tab
Clicked on "Default Point Spot Style 1" in left column
Clicked "custom color" box (did not change from the yellow that came up"
Clicked Build Tab
Saved
Clicked Build button
White progress bar pops up
1-2 seconds later program crashes without showing any progress in the bar.
Likes: 84 posts
Liked in: 186 posts
by benji33 » Wed Dec 04, 2013 9:37 am
Bug always opened
