Deleting hotspots, map view, map %
ImagoFactory
by ImagoFactory » Wed Nov 13, 2013 12:01 am
Hi everyone, I'm just discovering 2.0 and banging my head without a manual. Please help me with my problems.
Adding a map is easy; how do I renounce to have a map?
Setting zoom and center in project does not match with the final result.
By mistake I put wrong hotspots; how do I delete them?
Thanks in advance for your answer.
Re: Deleting hotspots, map view, map %
by benji33 » Wed Nov 13, 2013 10:50 am
- Zoom is not take in accompt at this time. Into a next beta release.
- To remove the map, simply remove the PanotourMaps plugin.
- Hotspots on map can't be removed yet. it will be done in a next beta release. It's a current task.
(note: can be removed manually into the .kpt of your project with a text editor into the "mapWeb" tag)
ImagoFactory
by ImagoFactory » Wed Nov 13, 2013 11:20 am
benji33 wrote:- Zoom is not take in accompt at this time. Into a next beta release.
Thanks for your answer. Which file should I manually modify? name_core.xml?
by benji33 » Wed Nov 13, 2013 11:25 am
No, save your project (File > save project as ...) into a YOUR_TOUR.kpt file.
Edit this YOUR_TOUR.kpt file and look after the <mapWeb> tag. Into this tag you have some <spot> objects. You have to delete the good one (spot node). It can be difficult to identify it into this file (the <gps longitude="-61" latitude="17"/> tag can help you to identify the spot to remove).
ImagoFactory
by ImagoFactory » Wed Nov 13, 2013 11:35 am
Ok, I got the idea. Thanks again.
