New PTP 2 Tour on Android / iPhone
LeeB
by LeeB » Wed Oct 30, 2013 3:52 pm
I published a test tour to view on some mobile devices here are my comments.
iPhone 4s
Tour looks great and everything works expect the control bar along the bottom went very small so very hard to use, not sure if there is a way to scale this up, I used the classic control bar. I also had the Combo Box in the top right corner that worked well and was very clear and easy to use.
Galaxy Note 3
Tour again looked good but this time all the hot spots, icons and menu boxes went really tiny to the point you couldn't even click on them, this included the Combo Box so it made it very hard to go from one tour to the next. I understand there is limited space on a mobile screen but if things are scaled down too small you can't use it. The combo box is the main thing I use on every tour as it's simple to use and people understand it so please make this work properly on Android.
Anybody else noticed the same problems when viewing on mobiles ?
Likes: 84 posts
Liked in: 186 posts
Re: New PTP 2 Tour on Android / iPhone
by benji33 » Mon Nov 04, 2013 11:51 am
I report your comment for our responsive design task on plugin. Thanks.
