Virus in Panotour 2?
Alberich
by Alberich » Tue Oct 29, 2013 8:00 pm
I am new in this community and i don't no is this the right section for my question.
I installed panotour 2.0 beta 2 on my windows computer and I get an alarm from my virus scanner (Avira Internet security) there is an Virus "TR/Crypt.XPACK.Gen5" in the File PanotourPro_win32_200B2_2013-10-17.exe.
Have everyone the same problem or an idee?
best regards
alberich
Likes: 14 posts
Re: Virus in Panotour 2?
by bdd » Wed Oct 30, 2013 10:19 am
Did you upload PTP from our download webpage http://www.kolor.com/download-autopano- ... tware.html ?
If yes, then it is a "false positive", and you can report it to avira with the avira tools.
Alberich
by Alberich » Thu Oct 31, 2013 8:11 pm
Yes I download it from your webpage. Is there no other one with the same probleme?
Alberich
Goecam
by Goecam » Tue Dec 17, 2013 10:02 am
Yes, there is a virus in the 32bit file. I've got the same problem.
The 64bit version is clean
by gkaefer » Tue Dec 17, 2013 10:52 pm
the Problem is that Internet is full of false positive questions about TR/Crypt.XPACK.Gen5.
if you downloaded kolor Software from kolor Homepage then you can feel safe.
the TR/Crypt.XPACK.Gen5 does collect and send your email address book to an email spammer and send unexpected email messages from your computer without your knowledge and also hackers can Access your pc... (2 minutes search on Internet)
autopano and panotour does use Software code inside which allows to send crashreports back to kolor. I suspect that your antivirus scanner does false positive recognize this ....
(Kaspersky and AVG do not recognize them...)
