Aliasing/jagged edges/render quality?
goshiota
by goshiota » Sat Oct 26, 2013 10:32 am
Hi All,
For some reason I'm getting really bad aliasing when generating tours with PTP 2.0. Not sure what I'm doing differently, but it seems to have started with the latest update.
Please see attached image. Any help on how to correct this would be greatly appreciated.
Thanks,
Jeremy
Likes: 80 posts
Liked in: 182 posts
Re: Aliasing/jagged edges/render quality?
by benji33 » Tue Oct 29, 2013 4:42 pm
Under Flash player or HTML5 player ?
Is it a full spherical panorama 360x180° or a partial panorama ?
Thanks.
goshiota
by goshiota » Tue Oct 29, 2013 6:44 pm
Hi Benjamin,
Thank you for responding. That is a screen grab from the flash version. It is indeed a full spherical pano, 360 x 180. The exact dimensions are 14044 x 7022.
Thanks in advance for any help.
Kindly,
Jeremy
aircamera
by aircamera » Wed Aug 13, 2014 9:12 am
Hi !
I also have some problems with aliasing on hotspots images.
Some of them have text into a .png image. It's difficult to read the text until you zoom on the spot.
Is there anything I can do to improve this ?
See : http://www.aircamera.fr/visite_virtuelle/intersport/360.html
Thank you for your help !
Cyril
Likes: 80 posts
Liked in: 182 posts
by benji33 » Wed Aug 13, 2014 1:47 pm
Bonjour ce problème n'a rien à voir c'est juste la compression de l'image qui est plus petite que l'image d'origine qui provoque ce défaut visuel.
Vous pouvez par exemple contourner ce problème avec des hotspots dont l'option "zoom" est désactivé en saisissant une taille d'affichage (width/height) où le texte affiché est le plus lisible.
by klausesser » Wed Aug 13, 2014 2:20 pm
benji33 wrote:Bonjour ce problème n'a rien à voir c'est juste la compression de l'image qui est plus petite que l'image d'origine qui provoque ce défaut visuel.
Klaus ;)
Likes: 80 posts
Liked in: 182 posts
by benji33 » Wed Aug 13, 2014 3:18 pm
klausesser wrote:???
Klaus ;)
Hi, this problem is not linked to previous post. It's an hotspot image compression.
You can change values width/height of the spot to reach a more accurate size with a better lisibility and remove the "zoom" option of the spot.
by klausesser » Wed Aug 13, 2014 4:47 pm
Klaus ;)
Hi Benji!
I meant: why suddenly in French? I don´t understand French - but i´m interested in this topic! ;) :cool:
aircamera
by aircamera » Thu Aug 14, 2014 10:28 am
I'm not sure...
When I open the same file with my browser ans resize the window until the picture hace the same size, it looks much better...
Likes: 80 posts
Liked in: 182 posts
by benji33 » Thu Aug 14, 2014 10:51 am
Yes but in this case it's not exactly the same size so the hotspot is "compressed" with a ratio with decimal values.
Look at theses tests (with zoom on left position / without zoom in right position) :
1. width + height = 0
2. width = 200 + height = 0
3. width = 300 + height = 0
So better way can be to generate a little image size (not the actual 772 pixels width).
