panorama autostart-PanoTour Pro 2 Beta 2
anna.ziabka63
by anna.ziabka63 » Fri Oct 25, 2013 5:37 pm
Panoramas do not auto start even if "use specific rotation parameters" checked
Liked in: 227 posts
Re: panorama autostart-PanoTour Pro 2 Beta 2
by Destiny » Fri Oct 25, 2013 11:14 pm
Perhaps you need to extent that part of the UI to see all of the settings....
BTW.. Once you add the AutoTour icon to the menu, it does it automatically... You do not need to do anything...
Likes: 84 posts
Liked in: 188 posts
by benji33 » Mon Oct 28, 2013 10:24 am
Yes autorotation settings are only for the speed/values.
Autorotation/Autotour must be started by a button or control bar or with the start parameters as Destiny said.
