Display Parameters (tooltip) box sometimes missing
seriousGeorge
by seriousGeorge » Fri Oct 25, 2013 10:37 am
The Box in the sidebar for the spot-properties, called "display parameters" is sometimes missing.
When adding a new spot, it's present. Sometimes if you click on a spot again the section "display paramters" is suddenly gone. You can only bring it back by deleting the old and adding a new spot or by selecting a diffetent spot style and then back again the style selected originally.
System:
Windows 8 64 Bit
PTP2 Beta 2
Likes: 82 posts
Liked in: 183 posts
Re: Display Parameters (tooltip) box sometimes missing
by benji33 » Fri Oct 25, 2013 12:01 pm
Yes it's an identified bug. Thanks, for report
