mtobarra wrote:Description:
1. Panotour Pro 2.0 project setup:
a. (style folder) Default Point Spot (action:Open the gallery on a specific image);
b. Hotspot on a Panorama: Open the gallery of the image to display=1
2. When I open the virtual tour on Internet Explorer 11 or Google Chrome, works fine clicking on the image spot.
3. When I open the virtual tour on Internet Explorer 8, when I click on the image spot, a blank box with a hourglass is opened but never the image is displayed. If I click on the status bar, this error is show:
Unable to get property 'preventDefault' of undefined or null reference
Kolorbox.min.js
code 0
line 60
Character 507
Thanks for you help.
mediavets wrote:mtobarra wrote:Description:
Kolorbox.min.js
code 0
line 60
Character 507
Which OS?
Are you viewing the Flash version of a tour or the HTML 5 version of tour?
Are you viewing an online tour, or viewing a local tour?
If a local tour are you viewing using the View last built tour... button in PTP 2.x?
mtobarra wrote:mediavets wrote:mtobarra wrote:Description:
Kolorbox.min.js
code 0
line 60
Character 507
Which OS?
Project Setup (general, tarjet: Viewer=Flash)
Windows 7, but the problem also occurs in Windows XP.
According the context menu, krpano Panorama Viewer is used
The problem occurs online and local. (online url: http://www.vistapanoramica.es/visitavir ... a/mca.html)
mediavets wrote:Description:
THis what I get with IE8 on Windows XP 32-bit.
benji33 wrote:Ok an javascript event should be incompatible with IE8.
I add a bug report. Thanks.
