PDF Plugin..
Likes: 3 posts
Liked in: 215 posts
PDF Plugin..
by Destiny » Thu Oct 24, 2013 9:17 am
Beta 2 - Mac
The PDF plugin seems to have real issues.... It cannot find the pdf. It used to be able to work as long as the url to the pdf was written in by hand in the xml code but not now.. If I try to change the location of the pdf, it never overwrites it. The old file will always remain. I set it to rebuild all files but this does not fix the issue.. When I try to delete the plugin and start over, PTP will crash.. No crash report created...
Likes: 60 posts
Liked in: 169 posts
Re: PDF Plugin..
by benji33 » Thu Oct 24, 2013 9:25 am
PDF url can be into the YOUR_TOUR.xml file (called from hotspot) or into YOUR_TOUR_skin.xml file (called from plugin).
You can find the line with : openPDF-PdfViewer string.
Crash when you delete plugin + add it again ?
Likes: 3 posts
Liked in: 215 posts
Re: PDF Plugin..
by Destiny » Thu Oct 24, 2013 10:19 am
I think the crash occurs due to the fact that the PDF plugin is still linked to the button so it does not like being removed until that link is removed.. This time I had a warning asking me.. Once I broke the link PTP did not crash.. When it crashed, I never got to see this warning...
Button top left...
http://www.destinyvirtualtours.com/Trop ... eShop.html
Question.. Is this PDF Plugin finished..?? Will there be a zoom feature..
