Pano Groups
adamali
Pano Groups
by adamali » Thu Oct 24, 2013 8:36 am
Hi All,
Is it possible to make group(s) inside a group?
Or showing group(s) in the panomenu only if specific group or pano selected?
Example for that I want to show the whole campus from outside buildings in the main tour. And if the visitor select specific building I want to show either the building for inside or categorizing the panoramas related to this selection in the Panomenu.
Likes: 84 posts
Liked in: 186 posts
Re: Pano Groups
by benji33 » Thu Oct 24, 2013 8:51 am
No, it's impossible.
PTP 2.0 host only 1 group level. Multi level will be applied later.
And conditionnal options for plugins on panoramas or groups not available too, but into the feature requests list.
Likes: 84 posts
Liked in: 186 posts
Re: Pano Groups
by benji33 » Thu Oct 24, 2013 8:52 am
You can edit the panoramaMenu into YOUR_TOUR_skin.xml file to remove unused sub-menus if needed and apply a link to top item of the menu.
adamali
Re: Pano Groups
by adamali » Thu Oct 24, 2013 8:57 am
benji33 wrote:You can edit the panoramaMenu into YOUR_TOUR_skin.xml file to remove unused sub-menus if needed and apply a link to top item of the menu.
Thanks for reply,
Currently I created the groups as I want them to be shown in the Pano Menu. But I was asking if the Pano Menu can be interactively change in each panorama which you said it is in the request list - as I understand- :)
Likes: 84 posts
Liked in: 186 posts
Re: Pano Groups
by benji33 » Thu Oct 24, 2013 9:02 am
adamali wrote:it is in the request list - as I understand- :)
Yes exactly, something very asked. Conditionnal plugins which can be applied only for one ore more groups and/or panoramas.
adamali
Re: Pano Groups
by adamali » Thu Oct 24, 2013 9:05 am
I will be waiting for this =D ;)
Likes: 84 posts
Liked in: 186 posts
Re: Pano Groups
by benji33 » Thu Oct 24, 2013 9:09 am
Be patient, it will be applied only into a 2.X version. We are currently working to finalize the 2.0 version. Actual step "beta 3".
Re: Pano Groups
by mediavets » Thu Oct 24, 2013 9:13 am
benji33 wrote:Be patient, it will be applied only into a 2.X version. We are currently working to finalize the 2.0 version. Actual step "beta 3".
It is disappointing to learn that conditional plugins won't be implemented in 2.0. =(
Likes: 84 posts
Liked in: 186 posts
Re: Pano Groups
by benji33 » Thu Oct 24, 2013 9:21 am
I know mediavets, but we take preference to solve all possible errors before adding a new feature which impact all components.
adamali
Re: Pano Groups
by adamali » Thu Oct 24, 2013 10:38 am
I think I should name that post "PanoMenu" instead of "Pano Groups" :rolleyes:
I faced new issue with the panomenu on the mobile devices "iPhone". The panomenu was "eating" more than 50% of the screen.
Why it is not scrollable!!? - I think it should be even on the PC devices-
I linked it to the show/hide properties but still I find it ugly when it is displayed :/
Likes: 84 posts
Liked in: 186 posts
Re: Pano Groups
by benji33 » Thu Oct 24, 2013 10:40 am
We have to apply a responsive design pass on HTML5 plugin for mobile compatibility.
Scrollable part is only applied to sub-menus corresponding to each group's panoramas.
adamali
Re: Pano Groups
by adamali » Thu Oct 24, 2013 10:44 am
benji33 wrote:Scrollable part is only applied to sub-menus corresponding to each group's panoramas.
I saw it for the panorama group, but what if we have many groups that reach to the horizon end? I think scrolling (left & right) is better that word warping the menu into two lines, at least on my case.
Making an option for which the user wants to use might help a lot in this case.
adamali
Re: Pano Groups
by adamali » Mon Oct 28, 2013 12:23 pm
I've noticed that the sctollable part shown in IE, but it was not there in chrome!!, May you please check from your side and confirm?
(http://www3.kfupm.edu.sa/VTour/KFUPM_VT/KFUPM_VT.html)
Re: Pano Groups
by mediavets » Mon Oct 28, 2013 1:09 pm
Seems to be there in Chrome (V. 30) on Windows 8.1 64-bit.
adamali
Re: Pano Groups
by adamali » Mon Oct 28, 2013 1:14 pm
Not for me!! :/
Windows 7 64-bit, Chrome (Version 30.0.1599.101 m)
Re: Pano Groups
by mediavets » Mon Oct 28, 2013 1:29 pm
Not for me!! :/
I was going to check with Chrome on Windows 7 Pro 64-bit, but it seems you have changed the menu?
adamali
Re: Pano Groups
by adamali » Mon Oct 28, 2013 1:33 pm
Yes, I'm now testing other menu types to find a temporarily solution for the menu on mobile devices.
I will return back to the Pnaomenu later :-)
adamali wrote:I think I should name that post "PanoMenu" instead of "Pano Groups" :rolleyes:
adamali
Re: Pano Groups
by adamali » Mon Nov 11, 2013 8:57 am
benji33 wrote:We have to apply a responsive design pass on HTML5 plugin for mobile compatibility.
I rebuild the project with the new beta version (3), but it seems that the menu issue was not resolved yet!!
still menu consumes big percent of the screen!!
EDIT // Website link was updated: (http://www3.kfupm.edu.sa/VTour/) //
Regards,
Likes: 84 posts
Liked in: 186 posts
Re: Pano Groups
by benji33 » Tue Nov 12, 2013 10:26 am
adamali wrote:I rebuild the project with the new beta version (3), but it seems that the menu issue was not resolved yet!!
Try your link on FF25 windows 7 / Chrome 30 windows 7 / IE10 windows 7 / ipad 3 safari 7 ios7 and scroll menu is working for me.
Is it an issue on the first load ? After a refresh works well ? After a resize of the navigator ?
Re: Pano Groups
by mediavets » Tue Nov 12, 2013 10:35 am
Regards,
Are you complaining that there are still no scroll bars displayed for long sub-menu lists? There are for me when viewing with FF25 on Windows 7 64-bit.
Or are you complaining that the menu and sub-menu elements do not scale with the size of the display?
Likes: 84 posts
Liked in: 186 posts
Re: Pano Groups
by benji33 » Tue Nov 12, 2013 10:45 am
Long sub-menus should display a scroll area. A resize of the windows update container value so scroll areas are resized too.
it's the standard case, and it's working for me with your url. Always the problem with a browser cache cleared ? With beta 3 release ?
adamali
Re: Pano Groups
by adamali » Wed Nov 13, 2013 6:36 am
mediavets , benji33
I mean the issue for the menu in iPhone that takes more than 30% in iPhone 5/S and much more in previous iPhones of the screen.
Likes: 84 posts
Liked in: 186 posts
Re: Pano Groups
by benji33 » Wed Nov 13, 2013 10:46 am
Main menu is not scrollable for the moment.
A combobox will be a better plugin for iOS devices to avoid the lost of space.
Thiago Lacerda
Re: Pano Groups
by Thiago Lacerda » Thu Nov 21, 2013 2:44 pm
i reckon that is a big issue, now-days every one has a smartphones, so the panorama menu must resize automatic on devices, if u work with a image as background for the menu, when u access on device its running out of the layout. very sad because the panorama menu s the best way to organise a tour with plenty rooms, have a look at some examples of my ones.
http://genericacom.com.br/tour/hotel-tabtinga/
http://www.nauroyal.com.br/360/
tks
fotojehle
Re: Pano Groups
by fotojehle » Thu Nov 21, 2013 5:06 pm
yes that's really true - Panorama Menu is very nice layout and versatile.
I hope it will be updated to automatic resize.
Felix
