TabStop in Description breaks xml
seriousGeorge
by seriousGeorge » Wed Oct 23, 2013 5:01 pm
I tested a description field for a hotspot and entered
Test, lorem ipsum lorem sit amet
Which resulted in an invalid xml for mobile (Fatal Error. Messages_en.xml Parsing failed). The reason was an accidentially TabStop I put there.
In Sublime it showed up as a "ESC". After removing the Escape-Character manually, the xml was fine and the tour showed up on the ipad.
I reproduced it several times... every time you hit the Tabulator key in the description field, the xml parsing is broken because of that unsupportet character.
Re: TabStop in Description breaks xml
by benji33 » Thu Oct 24, 2013 8:53 am
Thanks for this important test, I've reported it to correct it on next beta release.
