HTML5 Tour in Internet Explorer 11
lichtakrobat
by lichtakrobat » Wed Oct 23, 2013 3:48 pm
I have created a tour in Panotour Pro 2.0 Beta2. The tour works quite well, but in Internet Explorer 11 will not work the navigation and hotspots. IE11 will open the tour with HTML5.
However, there seems to be a problem in IE 11, because on the phone works the tour.
Is there already a solution method?
Likes: 82 posts
Liked in: 184 posts
Re: HTML5 Tour in Internet Explorer 11
by benji33 » Thu Oct 24, 2013 8:58 am
Can you try to put at the end of the url these 3 options :
YOUR_TOUR_URL?html5=never
YOUR_TOUR_URL?html5=always+css3d
YOUR_TOUR_URL?html5=always+webgl
This will try to load the player in Flash then in CSS3D HTML5 then in WebGL HTML5.
What are your observations ?
Thanks.
lichtakrobat
by lichtakrobat » Fri Oct 25, 2013 10:02 am
Hi Benjamin
This are my observations
benji33 wrote:
that works
benji33 wrote:
that does not work
benji33 wrote:
that does not work
I think IE 11 has a problem with HTML 5
Likes: 82 posts
Liked in: 184 posts
by benji33 » Fri Oct 25, 2013 12:06 pm
Probably because IE10 was working with CSS3D HTML5.
IE11 is still in beta version under Win 7+. Only released with Windows 8.1.
Which is you OS ?
lichtakrobat
by lichtakrobat » Fri Oct 25, 2013 12:36 pm
I'm using Windows 8.1
Likes: 82 posts
Liked in: 184 posts
by benji33 » Fri Oct 25, 2013 12:39 pm
Perhaps the player doesn't detect IE11 which have a totally new user agent string. I add a verification on this point in our todo list. thanks.
Likes: 13 posts
Liked in: 112 posts
by bdd » Tue Oct 29, 2013 5:05 pm
Next beta version of PTP will embed the new version of the krpano player : 1.16.9
This new version contains fixes for IE11.
ArneAlbers
by ArneAlbers » Thu Nov 07, 2013 11:02 am
Does it contain Fixes for chrome?
Likes: 82 posts
Liked in: 184 posts
by benji33 » Fri Nov 08, 2013 2:12 pm
Chrome has the same issue for you with beta 3 ?
