Loading Information Plugin
adamali
by adamali » Wed Oct 23, 2013 6:52 am
I tried to add "Loading Information" plugin to my project but it was not shown when I run the project.
I replaced it temporarily with "Loading Text".
Regards,
Re: Loading Information Plugin
by benji33 » Wed Oct 23, 2013 8:52 am
Do you use little planet introduction ?
What happens if you add "?html5=always" to the end of URL ?
Try on an online tour for "latence" test. You can send me url if needed for tests.
Tried with a bandwidth limitator and it's working for me.
adamali
by adamali » Wed Oct 23, 2013 9:23 am
benji33 wrote:Do you use little planet introduction ?
I tried with both checked and unchecked for the "start tour with little planet effect" checkbox with no change.
Actually even if it is checked the effect is not working (but this is another issue).
benji33 wrote:What happens if you add "?html5=always" to the end of URL ?
When I add the "?html5=always" to the end of the URL to preview the last built project the project was not working on IE, but when I test it on Chrome the loading percentage worked! So can we consider this an issue that will be fixed in next versions?
by mediavets » Wed Oct 23, 2013 9:27 am
Which version of IE and on which operating system?
by benji33 » Wed Oct 23, 2013 9:29 am
I've added a note to change something, but it's probably the Flash loader which consider the panorama already loaded. Try with an online url for latency tests.
adamali
by adamali » Wed Oct 23, 2013 9:30 am
mediavets wrote:Which version of IE and on which operating system?
I'm using IE9, for other application compatibility, with window 7 64
adamali
by adamali » Wed Oct 23, 2013 9:45 am
benji33 wrote:I've added a note to change something, but it's probably the Flash loader which consider the panorama already loaded. Try with an online url for latency tests.
The Online URL with latest built project
(http://www3.kfupm.edu.sa/VTour/KFUPM_VT/KFUPM_VT.html)
I add both the Loading information and loading text (Loading text appears under the information), but still on IE the information is not appear :/
by benji33 » Wed Oct 23, 2013 9:59 am
Tried on IE10, Chrome, Firefox : good for the two loaders in Flash and HTML5.
Tried on IE10 in IE9 compatibility mode : seems good in Flash player (IE9 doesn't support HTML5 player). Always bugged for you even with a cleared cache ?
