How to delete the Map Spot??
adamali
by adamali » Tue Oct 22, 2013 8:49 am
Hi All,
I added a Spot on the Map but unfortunately I could not delete it :/ !! So is there any way to delete the spot from the map?
Regards,
Re: How to delete the Map Spot??
by Destiny » Tue Oct 22, 2013 8:57 am
eemm.. Thats an old issue which was promised to be fixed.. The only way I can suggest, until this issue is resolved, is to edit your xml.. Delete the related spot code..
adamali
by adamali » Tue Oct 22, 2013 9:03 am
Thanks Destiny,
So we need to wait for this bug to be solved?
by Destiny » Tue Oct 22, 2013 9:20 am
Apparently.. =( If you need help editing your xml code, just let me know...
