Floor plan not visible
tamiro
Likes: 12 posts
Re: Floor plan not visible
by tamiro » Sat Oct 26, 2013 9:18 pm
mediavets wrote:
tamiro wrote:hi all
i hvae rebild the tour in a new project and still
the floor plan is not working at all
is i'm tring to see it not through PTP it dose not work
If you are trying to view locally (not online) the Flash version of a tour then you should use the View last built tour... button in PTP 2.x to ensure all features work correctly.
that's weird
so if i want to show or test offlinle project
i must use PTP?
by mediavets » Sat Oct 26, 2013 9:31 pm
tamiro wrote:
mediavets wrote:
tamiro wrote:hi all
that's weird
i must use PTP
No, you can use an off-line web server to deliver the tour.
Many more features in PTP 2.x are implemented in javascript and the Flash version of a tour must be delivered from a web server if all features are to work correctly. PTP 2.x has a small built-in web srever that is used when you use te View last built tour... button.
I understand that HTML5 versions of tours can be viewed offline directly.
by benji33 » Mon Oct 28, 2013 9:45 am
To visualize offline it's difficult without any modification of the flash plugin security access or chrome security access.
All browser are now done to block most of the scripts when called locally.
It's why a webserver local or online is the best way to visualize a virtual tour generated by panotour.
seriousGeorge
by seriousGeorge » Mon Oct 28, 2013 4:50 pm
Floorplan is definitley not visible when through localhost or online in fullscreen mode in IE and Chrome. Firefox is showing it fine in Fullscreen.
And when viewing the html locally without any server it's not shown by chrome (an we'll need that for an offline distribution without any server software involved sooner or later).
by benji33 » Tue Oct 29, 2013 3:51 pm
IE10 and minus doesn't support HTML5 fullscreen and FloorPlan is HTML5 plugin so FloorPlan is not visible in fullscreen mode.
Chrome have security settings to change to display page offline. Look at here : http://www.chrome-allow-file-access-from-file.com/
Localhost/online with chrome should be working.
You can send me an online exemple or a complete tour with the problem generated an zipped by [url]https://www.wetransfer.com/‎[/url] on contact@kolor.com (for Benjamin) for debug.
Previous
