Full Screen Disables Other Media...
by Destiny » Sun Oct 20, 2013 5:37 am
Beta 1 - Mac
I think this has been raised before... Not sure if its a condition of being in full screen or its a bug...
I have a JS Action which works great prior to full screen.. However, as soon as I enter the full screen its disabled.. Also, the exit full screen is still causing issues.. It does exit full screen.. But, I am sure I have seen it work at times.. This is a confusing bug since I do not know what is causing it...
http://www.destinyvirtualtours.com/JSeM ... eMail.html
Re: Full Screen Disables Other Media...
by benji33 » Mon Oct 21, 2013 10:55 am
After a test works well without fullscreen.
On fullscreen if click on hotspot, the image is not displayed until exit fullscreen where image is displayed at a wrong position.
So I think there is a concurrency problem between browser fullscreen and your script "Highslide JS".
DOM injection is good and image and layer seems behind the fullscreen (see into the 3D firefox inspector of layers).
by Destiny » Mon Oct 21, 2013 10:27 pm
Hi Benjamin..
It seems that a div content does not work in full screen since it overrides the browser, so the div parameters do not work, or at least thats how I understand it to be...Not sure if there is a solution to that.. Its nice to get other media working in PTP, it give is more value to the end user.. I guess my main use for PTP is to experiment with it.. Its what I use PTP for... mostly.. ;)
Other JS media can have some very nice effects, however, its use is limited for reasons like the issues with full screen.. The Highslide JS looks awesome on my Samsung Note.. I am only using media types that work with it...
Adding an image using the kolor website box has fewer issues.. However, the exit full screen on my Mac however still does not work... I have to press esc.. Its been reported in bugs way back...
by benji33 » Tue Oct 22, 2013 8:16 am
For fullscreen I know it's always an opened issue ...
