Embedded video crashes in Android
nicklange
by nicklange » Thu Oct 17, 2013 5:02 pm
I am new to panotour. love the software but ran into issue where an embedded mp4 video crashes when tour is viewed on Android. works fine on iphone. tour loads okay but the video does not.
Here is link http://alpha.pickeringcreative.com/liedcommons/ttt/liedcenter-commons2.html
Thank you in advance for your help.
Re: Embedded video crashes in Android
by mediavets » Thu Oct 17, 2013 5:54 pm
May be a CODEC issue - did you try with a different CODEC?
Can you view this video file outside of the tour on the same platform?
by benji33 » Fri Oct 18, 2013 9:02 am
Yes when video is unsupported, the thumbnail is not generated and provide an ERROR on the image file not found.
Try to encode video in low resolution for mobile compatibility (prefer encode with h.264/AVC, x264, avoid directshow encoders).
A video encode task is registered for later in our todo list.
nicklange
by nicklange » Fri Oct 18, 2013 8:57 pm
Thank you for responses. I will try to resave for mobile.
