Inserting MAP
prasad_peiris@yahoo.com
Inserting MAP
by prasad_peiris@yahoo.com » Thu Oct 17, 2013 9:16 am
We are using Panotour pro 1.8 with map feature to map tourism attractions with virtual tours. We were waiting till 2.0 version to make the mobile compatibility with all platforms. We cannot locate the Map feature in 2.0. beta. Can some one assist us to incorporate map function with panotour 2.0.
Re: Inserting MAP
by mediavets » Thu Oct 17, 2013 10:46 am
prasad_peiris@yahoo.com wrote:We are using Panotour pro 1.8 with map feature to map tourism attractions with virtual tours. We were waiting till 2.0 version to make the mobile compatibility with all platforms. We cannot locate the Map feature in 2.0. beta. Can some one assist us to incorporate map function with panotour 2.0.
The PTP 2.x equivalent to the Map (not Panotour Maps) feature in PTP 1.8 is called the Floor plan.
You can have a floor plan for the project overall, and/or for each group.
You need to add the Floor plan plugin from the Plugins library to your Workspace in the Style section and parameterise as desired.
Then you choose the graphics for Floor plans in the Project properties and Group properties panels in the Tour section.
If the project has floor plan you will see an icon on the main panel bottom left, if a Group has floor plan you will see an icon in the group 'container.
Click on these to display the floor plans in the Hotspot editor panel.
