Some menu buttons disappears in Galaxy Tab 2
Ramses
by Ramses » Tue Oct 15, 2013 7:08 pm
When I display the virtual tour created with PTP2 in Samsung Galaxy Tab 2 (Android 4), some navigation buttons disappear from the menu.
I tested it with Firefox, Chrome and Opera and it happened the same thing. What could be the problem?
Thanks,
Best Regards.
This is the correct menu
This is the menu in Samsung Galaxy Tab 2
bug in galaxy.jpg (102.16 KiB) Viewed 1105 times
Re: Some menu buttons disappears in Galaxy Tab 2
by mediavets » Tue Oct 15, 2013 7:36 pm
Ramses wrote:Hi,
Thanks,
Best Regards.
Menus are automatically 'optimised' for different platforms.
Kolor has deemed the missing buttons unnecessary for a device with a multitouch display.
Ramses
by Ramses » Tue Oct 15, 2013 7:57 pm
Thanks, and is it possible to show all buttons by modifying the XML?
by benji33 » Wed Oct 16, 2013 12:50 pm
Yes it's possible but not into the xml generated.
It's possible into the plugin TMPL file.
See informations here to make your own control bar into your panotour user directory : http://www.kolor.com/forum/viewtopic.php?f=91&t=20018#p128856
Once into the tmpl file look after the "devices=desktop" string to find buttons removed from tablets and mobiles.
