Previous and Next on Menu
by Destiny » Tue Oct 15, 2013 8:32 am
Beta 1 - Mac
This might not be a bug but it seems a bit odd...
If I set a View of a pano, it works using the Hotspots, but not the Previous and Next on the Menu..
Re: Previous and Next on Menu
by benji33 » Wed Oct 16, 2013 10:11 am
A custom view ? If yes it seems odd.
In fact a default view can be customized on a selected panorama. It's used by the prev/next buttons.
A hotspot can have it's own custom view which can be different if you doesn't use "default view" radio button but the "custom view" button.
