title font size adjustment does not stick
macalenny
by macalenny » Tue Oct 15, 2013 6:23 am
changed font size to larger than 10. go back, 10. does not stick to newly entered font size. ptp 2.0 Mac
Re: title font size adjustment does not stick
by mediavets » Tue Oct 15, 2013 8:23 am
macalenny wrote:changed font size to larger than 10. go back, 10. does not stick to newly entered font size. ptp 2.0 Mac
Known bug on Macs.
by Destiny » Tue Oct 15, 2013 9:47 am
.. Yes.. but until this bug is fixed, you can edit your xml code..
macalenny
by macalenny » Wed Oct 16, 2013 5:10 am
can you point me to where in the XML code I can change the font size of the title?
thanks!
by Destiny » Wed Oct 16, 2013 6:47 am
Hi. Sure.. In the #_skin.xml you need to find this line of code below.. If you try to change the size it will default to -1px... Here you can change the size to say, 12px, also the colour and position of the title etc..
The actual Title Text is in a different xml file.. That is in the #_messages_en.xml file..
Hope this helps.. I am sure the bug will be fixed soon...
<layer name="title_currentpanorama" keep="true" zorder="0"
url="%FIRSTXML%/graphics/textfield.swf"
align="top" x="0" y="0" width="100%" autoheight="true"
background="false" capture="false" handcursor="false" selectable="false" enabled="false"
borderwidth="0"
alpha="1"
visible="false"
textshadow="1"
css="text-align:center;
color:#000000;
font-family:Arial;
font-size:-1px;"/>
