Crash when deleting actions
pbetancourt
Likes: 25 posts
Liked in: 7 posts
by pbetancourt » Tue Oct 15, 2013 4:16 am
I'm using Panotour pro 2.0 with Mountain Lion 10.8.5
Under Style window I added two actions to a point, one to show an image, the other to show a web video box. The idea was to use the same style point on different hotspots, and just choose the action from the "Tour" window- Action parameters.
But after building the tour, the hotspot that has to show an image shows a blank video box instead. The hotspot that shows the video works fine.
So I decided to delete one of the actions and create a new point, but every time I click on the minus sign the program crashes.
Re: Crash when deleting actions
by mediavets » Tue Oct 15, 2013 8:22 am
As a workaround try deleting the Hotspot style from the Spots style list using the 'X' and then creating a a new one.
pbetancourt
Likes: 25 posts
Liked in: 7 posts
by pbetancourt » Tue Oct 15, 2013 1:34 pm
mediavets wrote:As a workaround try deleting the Hotspot style from the Spots style list using the 'X' and then creating a a new one.
Did it,
Many thanks
by benji33 » Wed Oct 16, 2013 12:06 pm
The problem (edit action crash) should be fixed in next beta version.
by mediavets » Wed Oct 16, 2013 1:23 pm
benji33 wrote:The problem (edit action crash) should be fixed in next beta version.
I get many instances of problems related to deletes and undos - will they all be fixed? Is it fundamentally the same problem in every case?
by benji33 » Wed Oct 16, 2013 1:34 pm
For "undo" it's another thing. italk about delete actions in this post.
Normally others crashs has been reported and are solved or are in a working task due to the priority of these bugs.
