floor plan image file type
macalenny
by macalenny » Mon Oct 14, 2013 6:01 pm
I tried to add an image to a group as a floor plan, it said invalid parameter, and when dragging the floor plan into the project (i want to add hot spots to it) there was a error message saying "grey images not supported". Can someone help me out?
Thanks!
Re: floor plan image file type
by mediavets » Mon Oct 14, 2013 6:06 pm
macalenny wrote:I tried to add an image to a group as a floor plan, it said invalid parameter, and when dragging the floor plan into the project (i want to add hot spots to it) there was a error message saying "grey images not supported". Can someone help me out?
Thanks!
Panotour doesn't support greyscale images.
But you can use B/W RGB images.
Panotour will also 'honour' transparency in image formats that support transparency such as PNG.
macalenny
by macalenny » Mon Oct 14, 2013 6:12 pm
ah got it, it's an image I was sent, changed to rgb in PS, working...
thx!
