Slow panoramas
Marko Pencek
Slow panoramas
by Marko Pencek » Mon Oct 14, 2013 2:15 pm
Why are panoramas so slow and get legs in Mozilla Firefox and also to Google chrome. They work in an Internet explorer a little better. In Panatour ver. 1.8 panoramas works pretty fine. I need solutions. http://www.helifoto.si/zadar/zadar.html
Re: Slow panoramas
by mediavets » Mon Oct 14, 2013 2:22 pm
Marko Pencek wrote:Why are panoramas so slow and get legs in Mozilla Firefox and also to Google chrome. They work in an Internet explorer a little better. In Panatour ver. 1.8 panoramas works pretty fine. I need solutions. http://www.helifoto.si/zadar/zadar.html
Slow?
I didn't find your tour at all slow when viewing with Firefox 24 on a Windows XP 32-bit over a relatively low bandwidth (1.5-2.5 Mbps) ADSL Net connection in the UK.
Marko Pencek
Re: Slow panoramas
by Marko Pencek » Mon Oct 14, 2013 2:30 pm
Hmmm... Very interesting. My local panoramas files and server files are same effect. Slow and legs. I have W7/64 and Firefox ver.24. My friend try access panoramas from Croatia (I´m from Slovenia) and tell me a same... legs in panorama auto rotation. I try different servers-same results. I have no idea what is wrong.
Re: Slow panoramas
by benji33 » Mon Oct 14, 2013 3:06 pm
After a test I doesn't see very visible differences in loading and rotations times. Perhaps little legs on Firefox but It's the flash plugin implementation into the browser.
You can try "?html5=prefer" behind url if html5 version is prefered.
As : http://www.helifoto.si/zadar/zadar.html?html5=prefer
Re: Slow panoramas
by mediavets » Mon Oct 14, 2013 3:08 pm
Marko Pencek wrote:Hmmm... Very interesting. My local panoramas files and server files are same effect. Slow and legs. I have W7/64 and Firefox ver.24. My friend try access panoramas from Croatia (I´m from Slovenia) and tell me a same... legs in panorama auto rotation. I try different servers-same results. I have no idea what is wrong.
Have you tried changing the rotation speed; be aware that there is a pause before autotation starts and the speed ramps up for a while after autorotation starts:
Marko Pencek
Re: Slow panoramas
by Marko Pencek » Mon Oct 14, 2013 6:49 pm
Thanks for all suggestions. I tray all. Here is a short video with my "legging" panoramas. I have two different pretty good computers, all updates, good graphic cards. Problem exist on both them. https://www.youtube.com/watch?v=mq1jy3Vgl74&feature=youtube_gdata_player
Yes. I must tell.... I converted all this (problematic) tour and panoramas from Panatour ver 1.8
jschrader
Liked in: 3 posts
Re: Slow panoramas
by jschrader » Tue Oct 15, 2013 4:07 pm
Marko, I suggest you try to edit the wmode-setting in your html.
Change it from "opaque" to "direct".
This is just to check if this is the cause because you may lose the js overlays.
Marko Pencek
Re: Slow panoramas
by Marko Pencek » Tue Oct 15, 2013 5:44 pm
I make "jschrader" suggestion. Yeees. It´s work! Great!! Now panoramas works without legs.
But now I got new problem. iControl bar (start/stop sound, show/hide floorplan, share the tour and full screen) are stop responding,
when I change it wmode-setting in my html from "opaque" to "direct".
Bug?
jschrader
Liked in: 3 posts
Re: Slow panoramas
by jschrader » Tue Oct 15, 2013 8:06 pm
Marko Pencek wrote:Hi,
Bug?
No bug, it's an unwanted feature.
That's the sadly truth.
Because the functions you are missing need a javascript overlay above the tour.
Unfortunately this overlay slows down the graphics performance even on fast computers.
So one can chose between smooth movement or full functionality.
The alternative would be to create it all from within krpano and avoid overlays.
Marko Pencek
Re: Slow panoramas
by Marko Pencek » Tue Oct 15, 2013 8:20 pm
"jschrader" thanks a lot for all informations. I hope on Color help in this story... In Panatour 1.8 all works fine.
HansKeesom
Re: Slow panoramas
by HansKeesom » Tue Oct 15, 2013 8:54 pm
I still see that in internet explorer the multires is not working well. IE loads each side of the cube one by one in high res, instead of first loading the lores version.
Re: Slow panoramas
by mediavets » Tue Oct 15, 2013 8:57 pm
HansKeesom wrote:I still see that in internet explorer the multires is not working well. IE loads each side of the cube one by one in high res, instead of first loading the lores version.
Which version of IE and on which OS?
Are we talking about the Flash versioj of a tour or the HTML5 version of a tour?
Marko Pencek
Re: Slow panoramas
by Marko Pencek » Tue Oct 15, 2013 9:10 pm
Same results in IE 10.0, Firefox 24.0 and Chrome 30.0
I have WIN7/64. We talk about desktop device tour version.
HansKeesom
Re: Slow panoramas
by HansKeesom » Tue Oct 15, 2013 9:10 pm
windows 7/64 ie 10.0.9200.16721
No idea what ie loads
Regards, Hans Keesom
Re: Slow panoramas
by mediavets » Tue Oct 15, 2013 9:17 pm
HansKeesom wrote:windows 7/64 ie 10.0.9200.16721
Right-click will reveal whether it's Flash or HTML5.
Marko Pencek
Re: Slow panoramas
by Marko Pencek » Tue Oct 15, 2013 9:35 pm
My tour works in Flash. Flashplayer plugin 11.9.900.117
HansKeesom
Re: Slow panoramas
by HansKeesom » Tue Oct 15, 2013 11:39 pm
does not say flash so I guess it is html5
Seems hard to repeat the effect and only at pano's that were taken in the air?
Re: Slow panoramas
by mediavets » Wed Oct 16, 2013 8:00 am
Screenshots 1 and 2 show the difference in Context menu entries between HTML5 and Flash.
Re: Slow panoramas
by mediavets » Wed Oct 16, 2013 8:04 am
Is this the sort of effect you are talking about? - See screenshot below.
I only see this with the HTML5 version of the tour with IE10 on Windows 8 Pro 64-bit, I don't see with the Flash version of the tour.
Re: Slow panoramas
by benji33 » Wed Oct 16, 2013 11:50 am
IE10 can use CSS3D HTML5 player (IE10 text info on right click) or Flash player (with ActiveX info on right click).
Probably the CSS3D version if tile loads as Mediavets screenshot.
Re: Slow panoramas
by benji33 » Wed Oct 16, 2013 11:53 am
jschrader wrote:No bug, it's an unwanted feature.
Yes, all javascripts plugins need the "opaque" attribute to be correctly displayed.
HTML5 only visits doesn't suffer of this problem, but at this time HTML5 visits doesn't offer all the Flash visits features.
Marko Pencek
Re: Slow panoramas
by Marko Pencek » Wed Oct 16, 2013 12:21 pm
Benjamin,
On personal computer (IE,Mozilla,Chrome) panoramas tour works in Flash on default. Flashplayer plugin 11.9.900.117.
How can i use all features of Panatour ver. 2.0 without legs and slow rotating panoramas?
Thanks!
Re: Slow panoramas
by benji33 » Wed Oct 16, 2013 12:41 pm
Have you tried the HTML5 version of the player ? Simply add "?html5=prefer" at the end of your URL.
Re: Slow panoramas
by benji33 » Wed Oct 16, 2013 12:47 pm
You can also use all features, but set all border radius to 0 if exists on plugins, and remove all plugins background transparency.
This should work even if you replace the wmode to "direct" rather than "opaque" into the HTML template.
Marko Pencek
Re: Slow panoramas
by Marko Pencek » Wed Oct 16, 2013 12:59 pm
Yes, I try preffer Html5 (http://www.helifoto.si/zadar/zadar.html?html5=prefer
But animation effect between two panoramas missing.
Did you in plan to solve this (background transparency, border radius,..) problems in next beta version?
