Crop settings lost after project restart
jschrader
Liked in: 3 posts
by jschrader » Sat Oct 12, 2013 3:47 pm
The crop settings in the hotspot editor are quite handy.
Unfortunately the settings get lost after the project was saved and restarted.
Which is a bit odd as I don't want to reapply these every time to 20+ panoramas of my project that need it. :rolleyes:
Oh, and while you are at it: Wouldn't it be possible to also set a limit not only for the vertical pan but also for the horizontal pan?
That way it would be MUCH easier to show just parts of a pano if desired.
Re: Crop settings lost after project restart
by mediavets » Sat Oct 12, 2013 4:23 pm
jschrader wrote:Oh, and while you are at it: Wouldn't it be possible to also set a limit not only for the vertical pan but also for the horizontal pan?
You can crop on the H axis if your pano has a HFOV of less than 360.
There is also a 'hack' that will allow you to crop a pano with HFOV on the H axis.
Select the pano then change the pano HFOV value to 359.
Select a different pano then again select the original pano (which you wish to crop) and you see crop handles on the H axis.
Crop, then change Pano FOV value back to 360.
jschrader
Liked in: 3 posts
by jschrader » Sat Oct 12, 2013 11:04 pm
HAHAHA! Very cool.
Now all I need is the hack to make those changes permanent.
ArneAlbers
by ArneAlbers » Fri Oct 18, 2013 1:38 pm
Jab quite annoying while editing a tour with 65+ panos...
by benji33 » Mon Oct 21, 2013 9:49 am
Yes it's a referenced feature in our todo list.
