Pixelation when loading
Aaron Eriksson
by Aaron Eriksson » Thu Oct 10, 2013 9:23 pm
I am finding pixelation when loading panos. The pixelation is not a smooth blur preview like other more expensive pano systems. I was give some code when the original VIP forrum went down. I never got a chance to correctly test with the alternate XML code changes. I would like to test it for you if someone remembers the situation. I have a link to my tour to show the pixelation.
http://www.bizsurfer.com/demos/jeffosborne/tour.html
Re: Pixelation when loading
by mediavets » Thu Oct 10, 2013 9:26 pm
Aaron Eriksson wrote:I am finding pixelation when loading panos. The pixelation is not a smooth blur preview like other more expensive pano systems. I was give some code when the original VIP forrum went down. I never got a chance to correctly test with the alternate XML code changes. I would like to test it for you if someone remembers the situation. I have a link to my tour to show the pixelation.
The VIProom forum content was moved here I believe:
viewforum.php?f=60
by benji33 » Fri Oct 11, 2013 8:54 am
Yes the preview file is blurry. It's a reported bug.
You can access Private Beta forum (if registered private beta user) in the bottom of the forums list.
