several issues (from Android to PDF)
eric_5dmk2
Liked in: 5 posts
by eric_5dmk2 » Thu Oct 10, 2013 8:58 pm
hello,
first of all, zi url:
http://www.360vista.fr/fra/baumette/baumette.html
I've added a PDF in the first pano (up in the sky). It is a leaflet with 2 pages.
There is an issue when trying to visualize the file with an iPhone. You cannot resize the pdf or scroll around.
The other main issue is with Androïd Phones. It just doesn't work:
Amongst other problems, regular crashes of the soft while working.
I've tried to change one loader to another (from picture to progress bar & loopings). Just won't work. I keep clicking on the selected loader and nothing happens. Don't have this issue with other projects.
Need help ;)
éric
Re: several issues (from Android to PDF)
by mediavets » Thu Oct 10, 2013 9:16 pm
Need help ;)
éric
What Android device, what version of Android, which browser and version?
eric_5dmk2
Liked in: 5 posts
by eric_5dmk2 » Fri Oct 11, 2013 8:07 am
Left Screen:
Motorola XT311
Android 2.3.5
Right screen:
Samsung GT-I9100 (S2)
Android 4.1.2
by benji33 » Fri Oct 11, 2013 9:23 am
1. Your first device seems to old to use HTML5 export WebGL or HTML5 export CSS3D or Flash export 10.
2. On your second android device, we have an issue with PDF url.
You can temporarilty change into baumette.xml file the line
<action name="onclickspotpoint37">openPDF-PdfViewer(baumettedata/spots/info_bau.pdf, spotpoint37_|PDF Box_|displaypdfpdf_title);</action>
into
<action name="onclickspotpoint37">openPDF-PdfViewer("baumettedata/spots/info_bau.pdf", spotpoint37_|PDF Box_|displaypdfpdf_title);</action>
3. On iPhone/iPad PDF can't be resized or dragged. Safari has an issue with the pdf player included into an <iframe>. I don't know yet if we'll be able to solve this problem.
Thanks for report.
eric_5dmk2
Liked in: 5 posts
by eric_5dmk2 » Fri Oct 11, 2013 10:52 am
hello and thanks for the update.
On the second Android's device, the panotour cannot be seens.
For the pdf on iDevices, the best option is to convert them into jpg files I guess.
Another wee error i've discovered this morning.
I get an error message at startup only with Firefox (it works fine with Safari & Chrome)
eric
by benji33 » Fri Oct 11, 2013 12:14 pm
Firefox AdBlock plugin blocks the dblclick.swf or dblclick.js file due to it's "/dblclick." filter option.
So we open an issue to change this file name.
Correction will be available into next beta version.
Likes: 14 posts
by bdd » Fri Oct 11, 2013 12:16 pm
eric_5dmk2 wrote:Another wee error i've discovered this morning.
eric
It seems that adblock does not allow the dblclick.swf plugin :-(
We opened the issue 2640 on this problem.
eric_5dmk2
Liked in: 5 posts
by eric_5dmk2 » Fri Oct 11, 2013 3:09 pm
disabling Adblock did indeed do the trick.
