Error reports are empty (0kb)
Patrick_s
by Patrick_s » Wed Oct 09, 2013 9:45 pm
PT2 crashes while working on hotspots. Time after time after time after time... Very annoying.
When looking at the crash reports, they seem to be empty. They are all 0Kb in filesize and empty.
Belgian webdeveloper and photographer.
Re: Error reports are empty (0kb)
by benji33 » Thu Oct 10, 2013 7:44 am
We have register you're problem.
Which type of hotspots work provide a crash please ?
Patrick_s
by Patrick_s » Sat Oct 12, 2013 2:57 pm
Normal round hotspots (Default Point Spot Style).
Just an observation: small projects with few hotspots seem to suffer less from these crashes. My project with +/- 40 hotspots crashed all the time. I've reduced it from 17 to 3 pano's to play with the styles and since, I have the impression that it crashes a lot less.
It may be a performance issue, because I have seen that AP2 generates loads and loads of temporary files!
Hotspot XML source:
<spot x="101.142" y="31.4973" relativeX="0.70761" relativeY="0.486631" type="point" objectId="252">
<description tooltip="test"/>
<presetAction id="user_defaultpoint0">
<action startPitch="0" targetId="121" category="basic" description="Load a specific panorama or the first panorama of a specific group." callTemplate="loadpanoramaactioncall.tmpl" depends="" sourceId="121" startFov="90" locked="False" customTargetView="False" type="Object" id="object" name="Go to a panorama or a group" internal="0" contentTemplate="" startYaw="0">
<select default="none" uiPreview="false" customize="true" id="sourcetransition" name="Source transition">
<item value="none" name="None"/>
<item value="zoominonspot" name="Zoom in on the spot"/>
<item value="zoomoutonpanorama" name="Zoom out"/>
</select>
<select default="loadspotview" uiPreview="false" customize="true" id="targettransition" name="Target transition">
<item value="spotviewtopanoview" name="Custom view to panorama view"/>
<item value="loadspotview" name="Load custom view"/>
<item value="loadpanoview" name="Load panorama view"/>
<item value="panoviewtospotview" name="Panorama view to custom view"/>
</select>
</action>
</presetAction>
</spot>
