[Beta 1] Crash when trying to delete an action from hotspot
scoopz
by scoopz » Tue Oct 08, 2013 11:49 am
If I click the minus button to remove the blank action on this hotspot PTP2 Beta 1 crashes every single time.
Here's the crash log it generates
Process: KCrashReporter [10194]
Path: /Applications/Panotour Pro 2.0.app/Contents/MacOS/KCrashReporter
Identifier: KCrashReporter
Version: ???
Code Type: X86-64 (Native)
Parent Process: ??? [1]
User ID: 501
Date/Time: 2013-10-08 11:38:10.009 +0100
OS Version: Mac OS X 10.8.5 (12F37)
Report Version: 10
Crashed Thread: 0
Exception Type: EXC_BREAKPOINT (SIGTRAP)
Exception Codes: 0x0000000000000002, 0x0000000000000000
Application Specific Information:
dyld: launch, loading dependent libraries
Dyld Error Message:
Library not loaded: /usr/local/Trolltech/Qt-4.8.5/lib/QtGui.framework/Versions/4/QtGui
Referenced from: /Applications/Panotour Pro 2.0.app/Contents/MacOS/./KCrashReporter
Reason: image not found
Binary Images:
0x100000000 - 0x10000dfff +KCrashReporter (???) <2DFA9D07-471B-354E-94E3-F58ECF647668> /Applications/Panotour Pro 2.0.app/Contents/MacOS/KCrashReporter
0x7fff62726000 - 0x7fff6275a93f dyld (210.2.3) <A40597AA-5529-3337-8C09-D8A014EB1578> /usr/lib/dyld
0x7fff8df77000 - 0x7fff8e2d6fff com.apple.Foundation (6.8 - 945.18) <1D7E58E6-FA3A-3CE8-AC85-B9D06B8C0AA0> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
For things like this, is a screenshot and crash log sufficient for you to file bug reports or would you prefer video screen captures if I have time?
Test System Spec: 15" Retina MacBook Pro, 2.7GHz i7, 16GB RAM, 768GB SSD, OS X Yosemite
Likes: 84 posts
Liked in: 186 posts
Re: [Beta 1] Crash when trying to delete an action from hots
by benji33 » Tue Oct 08, 2013 12:39 pm
A bug for this has been resolved (#2344) and a patch should appears into next beta version.
scoopz
by scoopz » Tue Oct 08, 2013 1:01 pm
Thanks. I've noticed several posts with #12345 as bug report numbers. Are these just for internal tracking or is there somewhere other than this forum where I can check to see if bugs have been identified and fixed since last release or are there any nightly builds that are available as well as the beta?
Likes: 84 posts
Liked in: 186 posts
by benji33 » Tue Oct 08, 2013 1:15 pm
Change lists between beta versions will offer the # of the corrected bugs or added features.
